HP Performance turbo kit...
Might be cheaper to get an 03/04 Cobra short block than the labor and pricefor forged internals in the 3V block.
If it's not, then stroke it with forged stuff.
I will say that I have heard from some guys on this forum that a single turbo on the 4.6L 3V is NOT the way to go. I hear that the twin turbo setup is a much better consideration. Unless you are going for numbers car only, but if you are going to drive the thing much you are going to have so much lag you wont ever really enjoy it. Who knows, I am no expert but I say do some research on choosing between single turbo and twin.
Well your stock block (as stated above) will take will handle 450 RWHP max -- if you start to go higher then that you're flirting with danger. Some things to consider since you want 600 RWHP --- you'll need to get forged internals to hold up the bottom end... fuel system... a stronger driveshaft... saftyloop (recommanded)... exhasut... gauges... etc. Don't forget about install as thats going to be pricy too
I actually got a chance to talk to someone at HP and he said that the kit with their tune is very safe and will put out great numbers. If you are going this route with an automatic trans, a good torque converter with a higher stall would be recommended. I'm torn between this and a Whipple.
ORIGINAL: JC Turbo
ok, not too shabby at all.... id like 500-600 HP what would i have to upgrade to acheive this? in a auto
plust the rods and pistons.
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
05, 08, 2011, automatics, hp, hpperformance, install, kit, kits, manual, mustanfg, mustang, performance, perfprmance, pics, support, turbo
