Issue Starting car cold
Old Dec 7, 2007 | 10:57 AM
sevenleaf's Avatar
sevenleaf
Default RE: Issue Starting car cold
ORIGINAL: 300GT
sevenleaf - what hood do you have there - looks mean.
I have cervini's #1171 thanks!
Old Dec 7, 2007 | 11:02 AM
GidyupGo's Avatar
GidyupGo
ORIGINAL: sevenleaf
GidyupGo: Your wrong please stop posting in the thread.
Not going to happen sevvy. It is a know, like down through the ages, that Fords ARE cold blooded. Now, it may or may not be what is hapening to YOUR car, but since we all just guess and try to help each other out based on our lifetime of experiences, for you to say I am wrong and to butt out is a bit ***-i-nine!
sevenleaf's Avatar
sevenleaf
Ok, I should add some more details. In the mornings when it sputters, I let the car idle forever still has issues, I tried revving the **** out of the car still sputters only way to fix it is to shut the car off then right back on no problems. I called brenspeed who said they are having this issue with thier cars and it's being looked at. They said they thought itcould be HT0's but they are still working on it. I datalogged 2 startups this morning emaild the logs to them hopefully the problem will fixed soon.
Old Dec 7, 2007 | 11:06 AM
GidyupGo's Avatar
GidyupGo
There have been issues with some Fords iceing up on the throttle body when it is real cold, but that mainly happens when extended driving has taken place, The fix was an insulating sleeve. Just rambleing here since this isn't your cause.
Old Dec 7, 2007 | 11:08 AM
sevenleaf's Avatar
sevenleaf
ORIGINAL: GidyupGo
Yeah but SC doesn't get really cold. My car isn't freezing its in the garage in 30° weather. Sorry to sound hash earlier.
Old Dec 7, 2007 | 07:16 PM
Gene K's Avatar
Gene K
ORIGINAL: GidyupGo
ORIGINAL: sevenleaf
WARNING: Hijack in Progress!
Hmmmmm.... I for one love the comparison between the Orignal Ford Model A (The first one before the Model T not the one after) and the Ford GT Supercar. Care to explain the shared parts that cause this?
Maybe its a ongoing 100+ year conspiracy between Henry Ford and the current engineers?
Old Dec 10, 2007 | 08:52 AM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
Yup known problem and most likely with the tune! Many have been having trouble with this and there is a fix and sawyer is a great help for me! shoot him a PM for his take on the subject seven! J
Old Dec 10, 2007 | 09:50 AM
GidyupGo's Avatar
GidyupGo
ORIGINAL: Gene K
ORIGINAL: GidyupGo
ORIGINAL: sevenleaf
Haven't been around long enough to comment on the Model T, but the 60's and 70's vintage had a heat riser issue with the 2100 2 B carb not letting the choke open up, and when it finally did, the choke spring would stay open and allow for a troublsome cold start. That's why they were known as cold blooded because they never wanted to warm up and idle. Good enough?
Old Dec 19, 2007 | 07:42 AM
sevenleaf's Avatar
sevenleaf
Ok I'm sure you guys are tired of hearing about all my problems huh ?
Ok I tracked down my starting issue. The dual pumps are causing a lot more pressure on the rubber duckbills attached to the fuel pump. It causing bad hesitation in the morning. I tore up 3 of these things already. First few times I pushed them on the tube to far this last time looks like my clamp was to tight. I put a 4th one on with a zip tie to see if that helps.
djbigskrilla
Sep 20, 2022 01:04 AM
mstahoo
SVT Forums
Aug 19, 2021 09:15 PM
ShaneB26154
35
Mar 4, 2021 04:05 AM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
