Hellion 76mm turbo ?
ORIGINAL: Black05StangGT
My hpturbo kit is on the way and Andrew helped me get an excellent deal on it...The specs on their kit far surpasses the specs on the other kits I was initally looking at...
To answer the OP's question about the ball bearing set up. From the research I did through Garrett turbos, streetability is improved with a ball bearing turbo, spooling slightly faster at a lower rpm and climbing the TQ curve slightly faster. The net result is the same, both turbos making the same power. For drag racing or for comparing 0-60 times, there was little or no difference since the car was already being started with a raised rpm. Per the info at Garrett's website.
Ball bearing turbos will also need more cooling. Most will use oil and water to keep the operating temps down. Journal turbos will generally work just fine with oil cooling.
I forget the size of my turbo, it's either 60 or 62, but it's rated for 620 HP. I beleive this would put me over 500 at the wheels if it was maxed out @16 psi. However, that won't be until after the engine build and a second turbo is added.
ORIGINAL: androdz
I know ball bearing turbos and journal bearings I have been messing with turbos with all my cars. I had a 02 sti, and I got a last gen supra.
Andrew
Andrew
?? 02 sti?
sti didnt come to the states untill 04, unless you made your bugeye an sti clone lol
I went ahead and ordered the hellion 62mm turbo with ball bearing upgrade today. I also ordered some steeda ultralight springs. Christmas is coming a lil early for me this year
ORIGINAL: meekstro
So would a ball bearing turbo be worth the extra cost....$400? My car is not a Daily Driver but stays on the street most of the time and at the track on occassion.
