window movement when opening door
ORIGINAL: marcuskeeler
................ if they freeze.
the original question was, have there been problems with it....
built into the motor.
Ford has not discovered a problem since 05 model year
and there is no TSB out on the subject. Never heard of
such a thing on the forum. If Ford was having problems
and having to do service to fix said problems,would it
have been redesigned and TSBed by Ford by now?
however Iam interested in knowing if there have been any problems with this function in the winter months when ice freezes the doors/windows in place
Thanks everyone. I appreciate the feedback. You have been very helpful. I had already checked for TSB's and recalls, and found nothing related, but you never know until you actually hear from an owner in the real world. Thanks again.
I did have a problem with this a couple of weeks ago, for some reason the window would roll all of the way up so when you closed your door the glass was on the top of the seal. I had the roll the window down just slightly so it would not hurt anything. I took it to the Ford Dealership and when i went to show them the problem it worked totally fine, made myself look like an idiot. Other than that not a single problem.
TSB-007
PROBLEM - WIndows Frozen in Closed Position due to Ice
RESOLUTION - Relocate Vehicle to Florida
