window movement when opening door
Old Dec 8, 2007 | 10:16 AM
05redfirepearlGT's Avatar
05redfirepearlGT
Default window movement when opening door
I know this sounds like a paranoid mustang owner but call it what you will. I noticed on my recently purchased 05 GT that when opening the door the window rolls down slightly thenrolls back up and seals upon the door closing. The total movement in either direction is approx. 0.250 - 0.500". This is a really great concept, however Iam interested in knowing if there have been any problems with this function in the winter months when ice freezes the doors/windows in place. Does anyone know if the motors have an autoreset feature to protect the circuit from popping a fuse when lost motion in the motor is detectedupon being commanded to move due to the door attempting to be opened? Thank you for your response in advance however petty this may sound.
Regards,
Chad R.
Old Dec 8, 2007 | 10:21 AM
marcuskeeler's Avatar
marcuskeeler
Default RE: window movement when opening door
There is an overcurrent limiter which disconnects power when the window is blocked.
However, if the window is that stuck then wanging the door open could be a whole different problem anyway[&:]
Old Dec 8, 2007 | 10:42 AM
bcstang's Avatar
bcstang
mmmmmm, glassback.
Old Dec 8, 2007 | 10:47 AM
downriverT's Avatar
downriverT
never had a problem
Old Dec 8, 2007 | 11:40 AM
157dB's Avatar
157dB
Cut & Paste Expert
Hmmm, no TSB on it and they have been around since 05 model year?
Old Dec 8, 2007 | 02:29 PM
Aziraphale's Avatar
Aziraphale
ORIGINAL: 157db
The windows are supposed to do it. They do it to get a better seal but to make it easier to open the door.
Old Dec 8, 2007 | 02:46 PM
SonicBlue05GT's Avatar
SonicBlue05GT
ORIGINAL: Aziraphale
ORIGINAL: 157db
the original question was, have there been problems with it....
Old Dec 8, 2007 | 02:49 PM
alex0o85's Avatar
alex0o85
I've had no problems.
Old Dec 8, 2007 | 02:54 PM
marcuskeeler
................ if they freeze.
Old Dec 8, 2007 | 02:56 PM
BWfVA's Avatar
BWfVA
I havent heard of any I wondered the samething but I figure ford accounted for this in some way or another. If they dont well I dont want the same reoccuring problem but the warrenty should take care of it or they will have a recall
