x-charger intake blow off/CBV?
I'm doing some research on the x-charger, the setup doesn't have an intake overpresure valve correct (Compressor Bypass Valve/Blow off)? If so, how dangerous is it not having one, and what is the process to install one?
RE: x-charger intake bypass?
It has a internal bypass just like the Eaton M90's that come on production cars and Roush's.
"low power consumption at part throttle with the By-pass Valve open can yield the same fuel mileage as stock. Very low parasitic loses because the X-CHARGER uses less than 1/3 horsepower when off boost"
The bypass is designed to disengage the x-charger below 2000 RPM, what I was reffering to was a blowoff valve where if you do hard braking and down shift the intake won't jump in presure between the charger and he closed throtle body.
ORIGINAL: Legion5
ORIGINAL: Gene K
Okay, like a turbo or centri. I didnt even know Roots used those.
ORIGINAL: Legion5
so that you don't over boost on decel
ORIGINAL: Legion5
ORIGINAL: moosestang
There is no blowoff valve on a supercharger. It has a bypass valve which closes when there is no longer a vacuum inside the intake manifold, ie. when the throttle is open far enough (about 1/2 throttle from my testing). It has nothing to do with rpms and as soon as you let off the gas it opens and the engine is back in vacuum.
ORIGINAL: Legion5
daltron
04-28-2016 08:10 PM
bradleyb
11-27-2015 07:50 PM
