Can it be done without the airbag deploying in my face? I need to clean out my car completely and I know I must have stupid stuff under there somewhere...
Don't even have to remove the battery cable. Use unplug the yellow wire harness under the seat.
You really should disconnect the battery. While in the act of prying open that connector, should the airbag deploy... even though there's a small likelihood it could go off, if it did deploy, 1) it is expensive to replace, 2) it could kill you if your face is in it when it goes.
ORIGINAL: YellowFlame
Why? The plug is two wires. There is no power to set off the airbag unless the sensor tells it to. The sensorsare not in the seat for the sit air bags. The wire harness is just like a plug into an outlet in your house. Except it is 12v DC not 110 AC. You cannot cross the wires.
