What oil are you using?
Old Dec 28, 2007 | 12:21 PM
  #21
Rubrignitz's Avatar
Rubrignitz
Default RE: What oil are you using?
You'll be ok. I'd never go over a 30w in these cars though. I've heard too many things about tighter tolerances and such even on the oil forums (where oil geeks hang out all day discussing oil blends and uoi's ). 0w20/5w20/0w30/5w30. I'd stick with those.
Old Dec 28, 2007 | 03:10 PM
  #22
157dB's Avatar
157dB
Cut & Paste Expert
5W30 in the 6 banger
Old Dec 28, 2007 | 03:20 PM
  #23
Dex's Avatar
Dex
I think I'll be trying Redline, Royal, and AMS out. All 5-30 to 5-50(since the GT500 uses it)
It would be interesting to dyno every fluid and see if there is a difference in HP and TQ gain. i'd do it for ****s and giggles
Old Dec 28, 2007 | 04:42 PM
  #24
ohnoesaz's Avatar
ohnoesaz
5w-20 mobil1, just like specs call for. If I had the $$$ I'd be ordering red line though....
Old Dec 28, 2007 | 06:03 PM
  #25
Blackhawk's Avatar
Blackhawk
ORIGINAL: Dex
There will be a difference between something like a 0W20 and 5W30 in terms of every last hp that you can get out of the car on the dyno..
As far as trying 5W50(cause the GT uses it)?
It's surely due soley in part to it being a 5.4 liter(different motor), and the fact it's forced induction. I personally wouldn't. But that's me.
Old Dec 28, 2007 | 06:37 PM
  #26
Burnsy's Avatar
Burnsy
ORIGINAL: Blackhawk
As far as trying 5W50(cause the GT500 uses it)?
Yeah, that and its also a 4V
Old Dec 28, 2007 | 07:04 PM
  #27
sailing220's Avatar
sailing220
Just because the GT500 uses 5W50 doesn't mean it should be used in the GT. That's like saying, "Oh, the Lamborghini uses ___ oil, I think I'll try that!" [/align]
Old Dec 29, 2007 | 09:10 AM
  #28
Rubrignitz's Avatar
Rubrignitz
You guys are right. Personally (and you can do anything you feel like with your own car), I wouldn't go with a higher grade oil than 30 weight (0w30, 5w30). If the Saleen s/c mustang only requires a 30 weight, with the heat and pressure it produces, then it's good enough for my ride too.
The more important thing than oil type is brand, with the different additive packages. Amsoil (and probably most other oil companies) purchase their PAO base stock from Exxon/Mobil. It's the additive package that makes the oil unique.
And as far as oil filters go, this is the "cats meow" of filters. Just bought 3 of them I was so impressed with their filtering ability (comparable to by-pass filter). I also use their synthetic (microglass) air filter on my C&L intake.
http://www.bobistheoilguy.com/forums...34&fpart=1
Old Dec 29, 2007 | 09:45 AM
  #29
07RedfireGT's Avatar
07RedfireGT
Mobil 1 5w20 synthetic
Old Dec 29, 2007 | 10:01 AM
  #30
Blackhawk's Avatar
Blackhawk
I think I might go out on the ragged edge and run 3qts of 5W20 and 3qts of 5W30!!!
And NOBDOY can stop me... [sm=teetertooter.gif]
