Prokit & 20" wheels, tires.
Old Jan 12, 2008 | 09:23 AM
loots06's Avatar
loots06
Default Prokit & 20" wheels, tires.
I'm wondering if those of you that havethe Eiback prokit and 20" wheels have had any problems with, steering, handling,clearance, rubbing in thefender well ect?I'll be purchasing wheels here very soonandinformation you provide will be helpful. Justfor information I will going with20X8.5(Front offset 18 or 28 ) and 20X10 (Rear offset 38). Which off set should I be going with on the front as I dont really understand. Can you also let me know what size tires you are running? I'm thinking about 255/45-20 and 295/40-20 respectively. Your assistance is greatly appreciated.
JP
Old Jan 12, 2008 | 09:45 AM
loots06's Avatar
loots06
Default RE: Prokit & 20" wheels, tires.
Help!
Old Jan 12, 2008 | 09:52 AM
loots06's Avatar
loots06
https://mustangforums.com/m_4392434/tm.htm
Old Jan 12, 2008 | 10:03 AM
marcuskeeler's Avatar
marcuskeeler
Why do people bump their posts after 20 minutes?
That's gonna get help sooo much quicker ! NOT
Old Jan 12, 2008 | 12:29 PM
MilehighGT's Avatar
MilehighGT
That tire size will put you an inch bigger on height size so consider that with the drop.
http://www.1010tires.com/TireSizeCalculator.asp
This will help compare tire sizes.
Old Jan 12, 2008 | 12:31 PM
MilehighGT's Avatar
MilehighGT
ORIGINAL: marcuskeeler
+1
Old Jan 12, 2008 | 05:18 PM
Black3vGT's Avatar
Black3vGT
Those tires are pretty tall especially the fronts. Drop the fronts to 255/35 or 255/40.
Old Jan 12, 2008 | 06:19 PM
06GT4RAD's Avatar
06GT4RAD
No problems with rubbing at all
front 245/35/20 rear 285/30/20
Old Jan 12, 2008 | 06:35 PM
Sleeper05's Avatar
Sleeper05
ORIGINAL: loots06
JP
I have the Sportlines and 20s. You won't fit 295-40s very easily. Go with a 275-35 instead and you'll never have a problem. 255-35 in front as well.
Old Jan 12, 2008 | 07:07 PM
grabberorange1's Avatar
grabberorange1
I'm running 255/40/20 fronts,you won't have room to run a 45 with the prokit. I have 275/40 rears and there is plenty of room to go with a 295,
jwog666
Dec 27, 2021 08:09 PM
mungodrums
Sep 28, 2015 10:54 PM
folivier
Sep 26, 2015 02:28 PM
lincolnshibuya
Sep 24, 2015 10:46 PM
