Are the calipers the same?
On a 2007 Pony Package V6 and on the GT model? Going to go order slotted/drilled rotors from brake designs but apparently they give two different options for rotors. I thought the caliper was the same size?
ORIGINAL: CroDalmatinac
So, I wouldnt be able to have the GT rotors fit properly, if ordered?
They are about $34 each from the dealer. I have the part
#s somewhere if you need them.
Also GT front rotors wont fit on 16" stock wheels with 39mm of offset.
You need the 17" 45mm offset or larger rims to accomidate the
larger rotors and moved calipers.
mungodrums
Sep 29, 2015 09:18 PM
maestro1024
Sep 21, 2015 02:40 PM
inyadreems
Aug 21, 2015 09:10 AM
