A/F Calculation using SCT Data Logging
Old Jan 19, 2008 | 09:57 AM
sailing220's Avatar
sailing220
Default RE: A/F Calculation using SCT Data Logging
Okay, another question.
How can I tell if my tune is rich?
[/align]
Old Jan 19, 2008 | 10:20 AM
HaneyMotorsport.Com's Avatar
HaneyMotorsport.Com
Banned
sailing, what you got is your rear cat monitors turned off. The rear O2s basically just monitor to make sure the cats are doing their job....working properly. Your front O2s are still working and in control of AFR in closed loop. As far as knowing what the real afr is, you need to get a wide band set-up.
Casey
Old Jan 19, 2008 | 10:23 AM
sailing220's Avatar
sailing220
I'm not really concerned with the actual AFR as a number, I just want to figure out if my tune is too rich. How can I figure this out? Are there any physical ways to tell? [/align]
Old Jan 19, 2008 | 10:29 AM
Blackhawk's Avatar
Blackhawk
A/F fluctuates too much throughout the rpm range to really "tell" if a tune is too rich or lean without a A/F meter.
Sure the old fashioned way is to pull and check the plugs, the tips of your exhuast,etc.
But I would get a A/F meter.
Old Jan 19, 2008 | 02:47 PM
FenderParrothead's Avatar
FenderParrothead
ORIGINAL: sailing220
+1
This is was a big part of why I asked my initial question. I understand that A/F fluctuates a lot, but I'd like to get some kind of usuable reading at idle and then again at WOT. Trying to find out if the SCT will do this for me. I'm really not interested in getting a wide-band set up just for this - at least not yet.
Is there really no other way to do this? Short of a wide-band or dyno shop?
Thanks again!
Nov 18, 2015 01:34 PM
piotrek53
Oct 13, 2015 06:54 PM
Oct 7, 2015 07:02 PM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
03blackwidow
Sep 20, 2015 02:36 PM
