stock tire size
RE: stock tire size
ORIGINAL: 06VistaBlueGT
Not sure this is true, 275 is the width of the tire in mm's. The 55,45 etc is the aspect ratio and has nothing to do with tire width. The only way I could see that the aspect ratio would have an effect on what width rim you are putting the tires on is if they allow a tire with a taller aspect ratio to be put on a narrower rim because the sidewall would be easier to pinch together to install on a narrow rim. The problem though is if you mount a tire on a rim too narrow is you make the middle of the tread buckle up and the sidewalls bulge out.The only way to adjust for correct contact patch is to under-inflate the tiresto flatten the tread and this could adversely affect handling.
ORIGINAL: 05Retro
Ihave 275-50-17 onmy rear 17x8 Bullitts. The measured rim width for this tire is 8.5 with approved rim widths between 7.5 to 9.5. The series of tire (55,50,45,40,etc.) helps determine the rim width not only the size like 275,265,etc. Look it up,to many people seem to group the 275 sizes into one rim width which is not true.
The taller the tire relative to to the width the narrower the wheel recommended.
Im not sure why this is true but it is.
RE: stock tire size
ORIGINAL: Allstar
whats the stock tire size for the 05+ GT?? cause mine have 275/?/17 and i highly doubt thats stock
They look more like factory 235/55R17 or at most 255/50R17.
RE: stock tire size
ORIGINAL: Gene K
Are you sure you didnt misread your tire size? Those dont look like 275's.
ORIGINAL: Allstar
That is what is on there by the way....i looked at the pic, they are the stock pirellis
NorthAmericanTuning
11-09-2016 11:44 AM
NorthAmericanTuning
03-18-2016 11:21 AM
