stock h pipe question
Old Jan 23, 2008 | 04:43 PM
w1ck3dr1's Avatar
w1ck3dr1
Default stock h pipe question
i was looking at the pypes o/r h pipe and the only difference i see between that and the stock h pipe is that it has no cats. wouldn't it be the same if i just welded pipes in place of the cats? i have a shop that will do it for 30 bucks. sounds like a good option to me. is there anything else that is different on the pypes?
Old Jan 23, 2008 | 04:44 PM
w1ck3dr1's Avatar
w1ck3dr1
Default RE: stock h pipe question
or maybe i can even cut the cat out and then gut it myself and weld it back myself. that would be even cheaper.
Old Jan 23, 2008 | 04:46 PM
onederful100's Avatar
onederful100
i think putting the pipes in place of the catswould be better airflow
Old Jan 23, 2008 | 04:48 PM
deekum1627's Avatar
deekum1627
sounds like a good idea
Old Jan 23, 2008 | 04:53 PM
w1ck3dr1's Avatar
w1ck3dr1
cool, just making sure there weren't any other differences.
Old Jan 23, 2008 | 05:35 PM
howarmat's Avatar
howarmat
s197 Junkie
just get the pypes h pipe......its worth it....hell its only $180
Old Jan 23, 2008 | 05:39 PM
doctorj77's Avatar
doctorj77
There is another difference. The "H" section is not a full 2.5. Maybe they changed something in 07 but when I took mine off I was pretty dissappointed. Probably around a 2in cross section, restricting flow. So with that said, it will not have the deepness of the O/R H which is full 2.5.
Another bummer. Up around the bell flanges, right side, top of pipe, there was a significant crimp in the pipe where they mounted the O2 plug at the factor, basically restricting that. I hear a lot of people say the stock H flows pretty good. And their right. But you want great flow, go aftermarket. BothO/R or Catted in any brand are better than stock.
Plus you'll more than likely spend around $60 at least in labor. Maybe not, everyone gets different labor quotes.
Old Jan 23, 2008 | 06:36 PM
UrS4's Avatar
UrS4
doctorj77 is correct about the diameter of the stock H pipe. Plus if you just weld pipe back in the cats location you will have to weld in a bung for the O2 sensor that goes into the cats.
Old Jan 23, 2008 | 08:39 PM
thewarmachine's Avatar
thewarmachine
Don't forget inspections. You might need that stock H-pipe with cats one day to pass inspection unless you plan on bolting on a friend's.
drfister
May 3, 2018 10:38 PM
Spiral534
Oct 6, 2015 04:31 PM
GimpyHSHS
Aug 29, 2015 06:30 PM
Soldier GT
Aug 12, 2015 03:46 PM
BlackShelbyGt500
Aug 10, 2015 11:50 AM
