Tires
Old Jan 24, 2008 | 12:05 PM
antipeterleague's Avatar
antipeterleague
Default Tires
on my newly purchased 08, the tire size is as follows: P215/65R16
i'm into wider tires with shorter sidewall, not too short though. where do those fit in?
Old Jan 24, 2008 | 12:18 PM
brad281's Avatar
brad281
Default RE: Tires
225 or 235 for wider. Aspect ratio for a shorter sidewall, but not too short of 40-55
Old Jan 24, 2008 | 12:23 PM
RED121572's Avatar
RED121572
Default RE: Tires
Thats an odd tire size. Is that what ford puts on Canadian GT's?
Old Jan 24, 2008 | 12:28 PM
Leos06gtLL's Avatar
Leos06gtLL
Default RE: Tires
it should be a V6 with those tires
Old Jan 24, 2008 | 12:33 PM
wolfie's Avatar
wolfie
Default RE: Tires
The GT's get 235's on the 17" and the 18" rims up here.
Old Jan 24, 2008 | 12:42 PM
antipeterleague
Default RE: Tires
it is a v6
Old Jan 24, 2008 | 01:20 PM
Argonaut's Avatar
Argonaut
Default RE: Tires
Don't know if you car is lowered but be advised, if you put a shorter sidewall on 16" rims, unlowered, you are going to have some big gaps between the tire and the fender, kind of a 4X4 look.
Old Jan 24, 2008 | 03:11 PM
SCCAGT's Avatar
SCCAGT
Default RE: Tires
To get the lower profile, you will need to go to a larger rim.
If you change the tire size to 225/60 on the same 16" rim, The tire diameter is still the same. The look will be the same except it would be slightly wider. And as someone else said, to drop down to a lower profile, of say 50, you would need a 245 (to keep the same diameter). That wont fit too well on the stock rim. Might look kinda stupid.
[sm=icon_rofl.gif]Or just do whatSOME peoplefrom south of the border do. Put some rubber bands on the stock rims, and call it good.[sm=icon_rofl.gif]
Old Jan 24, 2008 | 03:13 PM
antipeterleague
Default RE: Tires
it's not lowered or anything. i guess i'll jsut look into wider tires.
is it cool to have wider tires at the back and not the front?
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
KingRando
Oct 2, 2015 08:06 AM
marc954
Sep 29, 2015 11:18 AM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
