Rear diff. fluid
Old Jan 24, 2008 | 09:52 PM
slvrstang2007's Avatar
slvrstang2007
Default Rear diff. fluid
I am putting on a new drive shaft, pulled off the pimiom flange and a little bit of really dark fluid came out, so I want to put some fresh diff fluid in and cant find what kind it takes anyone know? I know dumb question but cant seem to find the answer anywhere else. thanks.
Old Jan 24, 2008 | 11:09 PM
Ford_Dude's Avatar
Ford_Dude
Default RE: Rear diff. fluid
I think its 75W140
http://www.brenspeed.com/mustang_2005/images/01301.gif
or
http://www.jegs.com/webapp/wcs/store...52195_-1_10673
Old Jan 25, 2008 | 07:29 AM
partsbill's Avatar
partsbill
Motorcraft SAE 75W-140 Synthetic Rear Axle Lubricant
Ford Part# XY-75W140-QL
Old Jan 25, 2008 | 09:00 AM
Gene K's Avatar
Gene K
Note that Ford has revised the fill level from 1.0-1.125" below the hole to even with the hole.
Also if you are changing the fluid you will need Motorcraft XL-3 Friction Modifier Additive to keep the clutches from chattering.
Dont use anymore than absolutely required unless you like rebuilding your Traction-Loc.
67LimeCoupe
Sep 30, 2015 04:46 PM
Sep 16, 2015 07:53 PM
LivingInThePast
Sep 16, 2015 12:20 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
IronRaptor
Sep 9, 2015 08:10 AM
