Shift Light Question
Old Jan 26, 2008 | 08:47 PM
whtcanbrwnd04u's Avatar
whtcanbrwnd04u
Default Shift Light Question
Those of you with the shifter lights, are they easy to set-up? Do you have to have a predator tune to set it up? Where did you order it? I want one asap. Thanks.
Old Jan 26, 2008 | 08:56 PM
Black_06GTStang's Avatar
Black_06GTStang
Default RE: Shift Light Question
I personally like the Raptor shift light. I've been using it for a while and am happy with it. You don't need a tuner, just install and you can use dials on the side to adjust at what rpm you want it to light up. really easy to use.
You can check them out here.
http://www.raptorperformance.com/
Old Jan 26, 2008 | 08:57 PM
Stkjock's Avatar
Stkjock
Retired Mod
get the Raptor... very easy to install and inexpensive.....
Old Jan 26, 2008 | 09:04 PM
StickShifty's Avatar
StickShifty
raptor is a self contained unit, you dont need a monster tach, or external unit. very easy to install, its only a few wire connections. i think with the S197 you have to run a wire through the firewall. thats the hardest part.
black raptor with yellow LEDs in the air vent is the ONLY way to do it.
Old Jan 26, 2008 | 09:07 PM
Larmo's Avatar
Larmo
PMP makes a nice one...
Old Jan 26, 2008 | 09:13 PM
howarmat's Avatar
howarmat
s197 Junkie
https://mustangforums.com/m_3545524/...tm.htm#3545524
This is the best ive seen yet....i have had mine installed for about 6 months maybe with no problems
Old Jan 26, 2008 | 09:18 PM
mlcrycc's Avatar
mlcrycc
Another vote for the Raptor.....
[IMG]local://upfiles/13557/010C2837650543849FCD983FB6421332.jpg[/IMG]
Old Jan 26, 2008 | 10:00 PM
whtcanbrwnd04u
Thanks guy. Appreciate it.
Old Jan 26, 2008 | 10:10 PM
blackout's Avatar
blackout
Raptor in the A/C vent for me.
Very easy install as follows:
-Set your RPM's on the Raptor
-Find where you want to place it
-Tap into fuse on passenger side kick panel with one wire
-Tap into coil with another wire (don't use the red one)
-Ground the final wire!
Old Jan 26, 2008 | 10:50 PM
thewarmachine's Avatar
thewarmachine
What is a shift light used for?
