If you mount it at the correct position on the dash there are no gaps. I also took a fine file when I installed mine and trimmed the edge to match the contour ofmy dash. The pod does not use 3m tape all the way around because the edge is very thin. If you spend a couple minutes fitting it you'll be pleased with the result.
Thanks for the clarification..I have the thing sitting in my basement and the car is put away so these are first photos I've seen of the pod installed. I currently have the cdc pod which is ok but I like theway autometer has angled the gauges and finish to match the dash.
