removing the antenna???
Old Feb 5, 2008 | 07:12 PM
pascal's Avatar
pascal
S197 Section Modder-ator
Default RE: removing the antenna???
To the OP, my bad...
I thought you wanted to yank the base out also...
If you leave the base it won't cause you any problems, just look funny.
Old Feb 5, 2008 | 08:24 PM
kdrshocker's Avatar
kdrshocker
ud be alright removing it - BUT if water builds up in that small hole you might get some rust in it over time.
Old Feb 6, 2008 | 04:40 AM
TOMBSTANG's Avatar
TOMBSTANG
dont waste your money on a stubby. You ca buy a internal antena for $20 and It gives you as good if not better reception then the stock antena, shorts tent to loose some stations and they still blow cause you have a antenna. You will thank your self in the end if you spend the small amount of money to buy the internal and have the gap filled and painted on the fender.
Old Feb 6, 2008 | 05:19 AM
JudisStang's Avatar
JudisStang
Why leave the hole open to collect water on such a nice ride? I bought one of these, painted it black and I think it's a better idea than leaving open - unless you are going to a body shop and getting it removed completely.
Old Feb 6, 2008 | 10:07 AM
06Redfire3V's Avatar
06Redfire3V
ORIGINAL: TrIpOd
maybe you guys are misunderstanding me. i want to ONLY remove the antenna by unscrewing it, leaving the black plastic cap ON. anything wrong with doing doing this?
No nothing wrong w/ it. I have had mine off for about 2 months now absolutely no problems
Old Feb 6, 2008 | 10:13 AM
Ran's Avatar
Ran
ORIGINAL: JudisStang
Nice! Where'd you pick that up?
Old Feb 6, 2008 | 10:18 AM
GidyupGo's Avatar
GidyupGo
That looks great! If the OP ever did want to cut it down, I remember some time ago about a thread where a guy explained how radio waves wrok with anteni. The thought was that the length was directly related to the ability to pick up radio waves. Not just a shorter one won't work as far kind of deal, but that they had to a specific length and if cut down, it had to be done mathmaticaaly in order for the thing to work.
Old Feb 6, 2008 | 11:34 AM
05MustangSally's Avatar
05MustangSally
Pignprocess is right. I would eventually go with the internal antenna and get the old one shaved off. Looks better complete without. I heard of bad reception with the shorter antennas so kind of a waste of money considering it's still showing too.
Old Feb 6, 2008 | 11:41 AM
sandy's Avatar
sandy
I cut mine down 18", and it looks and works great. Opps, that's right, I've never turned on my radio!!
Old Feb 6, 2008 | 11:42 AM
Black05StangGT's Avatar
Black05StangGT
Mine is in the body shop getting a few things done, one of which is removing the antenna and getting a power anntena installed under the rear view mirror...so I'll have my antenna removed and still havea better powered antenna that looks pretty stealthy...
