Keyless entry keypad
Old Feb 10, 2008 | 01:02 PM
StickShifty's Avatar
StickShifty
Default Keyless entry keypad
what website did you buy yours from. and how did you program it??? post any pictures please.
thanks
Old Feb 10, 2008 | 01:18 PM
pascal's Avatar
pascal
S197 Section Modder-ator
Default RE: Keyless entry keypad
Bought mine from Ford.
The programation is explained in the instructions.
You have to round up all your key fobs together in the car with you and program evrything at the same time.
Lot of folks put it by the wipers. It's a good place for it.
Old Feb 10, 2008 | 01:39 PM
StickShifty
sound easy, thanks
Old Feb 10, 2008 | 01:45 PM
howarmat's Avatar
howarmat
s197 Junkie
https://mustangforums.com/m_3981103/tm.htm
I did this....even fit on the back of my chrome replacement....its not the one pictured but the new one listed here is smaller
http://www.fordaccessoriesstore.com/...ries.asp?id=38
Old Feb 10, 2008 | 01:46 PM
pascal's Avatar
pascal
I'm working on a different spot that might work for some of my customers.
Here are a few pix...
Not far from the door handle, you have to cut the window felt moulding ($32 retail)to make room for it, right on the top of the door.
[IMG]local://upfiles/78700/35F14922C43C479B8B089A16F311A687.jpg[/IMG]
[IMG]local://upfiles/78700/8A86EFFE420244699DBBEEFBD61ACD56.jpg[/IMG]
Old Feb 10, 2008 | 01:55 PM
StickShifty
thats i am going to put mine on the back of the fuel door.
so i guess you can program them yourself from inside the car? you dont have to send it out?
Old Feb 10, 2008 | 01:59 PM
pascal's Avatar
pascal
Don't send it out... It's easy with the instructions, it comes with a code already set for you.
I did it myself and I'm anelectronic retard[8D].
Old Feb 10, 2008 | 03:04 PM
partsbill's Avatar
partsbill
bought mine from ford and mounted behind fuel door.
Old Feb 10, 2008 | 03:07 PM
StickShifty
ORIGINAL: pascal
but i dont see how it gets programmed to unlock the car, like on the same frequency or however it works. i understand how to program your personal code. ah whatever, just ordered one.
Old Feb 10, 2008 | 03:23 PM
partsbill's Avatar
partsbill
you program it just like you program a new key fob, the instuctions are in your owners manual, you have to reprogram your key fobs at the same time as your programming the key pad, the key pad come with a 5 digit code, you can't change it.
