What parts for diff. gears install?
Old Feb 11, 2008 | 02:02 PM
Xplosive22's Avatar
Xplosive22
Default What parts for diff. gears install?
I have an '07 GT and I want to put 3.73's in over my stock 3.31. I am probably going to buy from AmericanMuscle.com but I'm not sure if I need both kits they have listed. I'm assuming I have to get the $75 bearing kit, but there is an "installation kit" also for $35. Do I need both? My car has about 16,500 miles if that has any weight on whether it needs bearings or not.
I also read other postings where people were talking about recalibrating the speedometer. Is that necessary?
Any help is appreciated. I don't want to waste money buying things if I don't need them. Does anyone have an approx. install cost too?
Old Feb 11, 2008 | 09:05 PM
Argonaut's Avatar
Argonaut
Default RE: What parts for diff. gears install?
I don't know if the bearing kit is required...I don't think it is but not sure. The install kit is.
But - as you probably know this is not a do it yourself mod. You will need to find a competent shop, with Ford 8.8 rear end experience. Talk to them, you can probably order thru them or at the least they will tell you what is needed.
Yes - recalibrating the speedo is required because your rear tires will be rotating at a faster rate per the same engine RPM. You can do this yourself with a tuner like the XCal2 or equivalent. If not your speedo will be off.
Install cost varies by local but minewas $550 for labor, gears, kit and fluids.
Old Feb 11, 2008 | 10:19 PM
Xplosive22's Avatar
Xplosive22
Even if I knew how to do it properly I wouldn't. I'm way too lazy to do work that technical. I'm guessing if it is a reputable shop they will have the necessary handheld to reprogram for the gear difference. I'll make a call tomorrow and find out what it'll cost. My only concern is buying the two kits which puts me over budget. If it is necessary then I'll do it obviously. I just need that information to order.
I hope being that the "Master Bearing Kit" on AM.com is Motive brand that it won't being a sacrifice of quality. It isn't exactly cheap anyway.
Thanks for the info though. $550 sounds pretty good for the whole package. I keep forgetting that oil needs to go back in.
djbigskrilla
Sep 20, 2022 01:04 AM
drfister
May 3, 2018 10:38 PM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
HorsePower99
Aug 26, 2015 11:29 PM
Mnuckolls
Aug 9, 2015 08:54 AM
