shaky wheels??? HELP???
Old Feb 20, 2008 | 04:46 PM
surfbum7190's Avatar
surfbum7190
Default shaky wheels??? HELP???
i got new wheels a couple weeks ago and took them to the goodyear shop near my house to get them installed. (i took them there cause i got my tire pressure sensors switched over) however now whenever i hit cruising speed my steering wheel is all messed up. Is it the wheel alignment or balance? or a loose lug?
Old Feb 20, 2008 | 04:51 PM
americaniron's Avatar
americaniron
Default RE: shaky wheels??? HELP???
Most likely a balance issue.
Old Feb 20, 2008 | 05:22 PM
Orion_240's Avatar
Orion_240
they probably didn't rebalance the wheels. Did they come with wheel weights on them? On both sides? Even the best wheels will require some balancing.
Make sure they didn't charge you!
Old Feb 20, 2008 | 05:24 PM
red07gt's Avatar
red07gt
+1...definitely sounds like a balance problem.
Old Feb 20, 2008 | 05:41 PM
whtcanbrwnd04u's Avatar
whtcanbrwnd04u
Either balance problem like stated above, or one of your bands might be broken.
Old Feb 20, 2008 | 05:50 PM
vphokie's Avatar
vphokie
Might need road force balanced, or even worse, maybe one of your rims is bent or the tire is faulty. Not to scare you into thinking worst case scenario....I've had to road force balance my wheels...and the most recent time I got vibration, I found out one of my rims is bent.
Old Feb 20, 2008 | 05:55 PM
Javdog's Avatar
Javdog
I had the same problem when I got my new wheels they balanced them and when I drove on the freeway I got alot of steering vibration, they had to balance the wheels from the back side of the wheels instead of the front side, once they balanced from the back side of the wheels the vibrartion went away and now its a smooth ride.
[IMG]local://upfiles/67105/072EC2FCD7EE4746BAC3930E6150B53A.jpg[/IMG]
Old Feb 20, 2008 | 06:10 PM
thewarmachine's Avatar
thewarmachine
Might be the retaining clip on the wheel studs. You need to remove these to make the rim sit flush against the hub.
Old Feb 20, 2008 | 06:19 PM
mlcrycc's Avatar
mlcrycc
ORIGINAL: thewarmachine
+1.
[IMG]local://upfiles/13557/3B476C499C3F4C2F9688B714E9964091.jpg[/IMG]
jwog666
Dec 27, 2021 08:09 PM
UrS4
Oct 3, 2015 06:23 AM
mungodrums
Sep 28, 2015 10:54 PM
folivier
Sep 26, 2015 02:28 PM
lincolnshibuya
Sep 24, 2015 10:46 PM
