skip while accelerating
Old Feb 21, 2008 | 09:50 PM
parcar1's Avatar
parcar1
Default skip while accelerating
I've got a 2006 GT Conv w/ about 4k miles. Have had a few incidents where the engine "skips" pretty hard while accelerating (ie. trying to beat a red light).It almost felt like I had water in the gas or a misfire....took it to dealer, and got the "we can't make it do it" reply...
Any suggestions?
Old Feb 21, 2008 | 09:55 PM
jmk3's Avatar
jmk3
Default RE: skip while accelerating
If it was after a long drive it may be the fuel pump, there is a tsb for it, there are tsb's listed here, try the search.
S197steve's Avatar
S197steve
ORIGINAL: parcar1
Any suggestions?
Don't try to beat red lights...
Seriously though, did thay happen on the same tank of gas... or multiple tanks?
Old Feb 21, 2008 | 10:00 PM
parcar1's Avatar
parcar1
It's happened on multiple tanks and different situations.
1. was turning right at a stop light w/ about a 1/4 tank left
2.accelerating to get through intersection
3. turning left from stand still
situation 2 happened w/ I punched it, the others were just moderate take-offs
Old Feb 21, 2008 | 10:03 PM
S197steve's Avatar
S197steve
Hmm... weird.
I'm alittle confused when you say it 'skips'... Does it bog down, rev up, feel like the clutch is slipping... etc..
Old Feb 21, 2008 | 10:07 PM
parcar1's Avatar
parcar1
hits passing gear w/ engine rev'd, then skips/chugs like air or water was in the fuel line. then takes off again. hope there weren't any witnesses...
Old Feb 21, 2008 | 10:13 PM
bmk's Avatar
bmk
are you auto or manual? it could be bogging down due to you not giving it enough gas when easing off the clutch(if you were manual)
Old Feb 21, 2008 | 10:19 PM
parcar1's Avatar
parcar1
It's an automatic. sorry, guess that was an important factor in my post that I left out.
Old Feb 21, 2008 | 10:21 PM
explict's Avatar
explict
turn traction control off?
Old Feb 21, 2008 | 10:25 PM
bmk's Avatar
bmk
do the rev's go up when it switches gears imediately?
