AUDIO CONTROL MODULE PROGRAMMING
Old Jan 24, 2009 | 09:25 AM
Michelle Cole's Avatar
Michelle Cole
If I am not mistaken, I believe I read someplace that you can't have the shaker 1000 with a nav system, that only the shaker 500 was compatible with it.
Old Jan 24, 2009 | 11:50 AM
157dB's Avatar
157dB
Cut & Paste Expert
Originally Posted by data174
Has anyone come up with a solution how to upgrade the ACM shaker 500 to the Navigation radio. I installed the Nav radio on my 2009 Mustang,all appears to be working except the the B2477 configuration failure.
I used the ford ids vcm and did what they advised. Still get the B2477 error.
If you go to the as-built it will only scan for my as-built information with the shaker 500. How do I get Navigation configuration.
Have you looked up the B2477 error to findout what it was?
Old Jan 31, 2009 | 09:49 AM
data174's Avatar
data174
Just an update on the ACM configuration on the Navigation unit installed. The ACM must be programmed with as-built data from a navigation radio installed at the factory. This will remove the B2477 configuration failure DTC.
The update worked, no more B2477 configuration failure DTC.
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Oct 6, 2015 08:45 AM
UrS4
Oct 3, 2015 06:23 AM
ChampInSD
Oct 2, 2015 04:55 AM
ThatJuanStang
Sep 25, 2015 08:01 AM
