drilling suggestions...
Old Mar 2, 2008 | 05:54 PM
mdg's Avatar
mdg
Default drilling suggestions...
I've ordered the GT500 spoiler and will have to drill the holes in my trunk since I have the spoiler delete option. What is the best way to do this? Do I need to place tape over the spot that I'm drilling to protect the paint? Suggestions appreciated as it will be hard enough to get up the nerve to do this. My other option is to have the body shop at my dealer do it for $80.00. Thanks!
Old Mar 2, 2008 | 06:03 PM
Fred Malibu's Avatar
Fred Malibu
Default RE: drilling suggestions...
If you have a template for it place that over the trunk. Then, use an auto-center punch on the holes in the template. This will set the spot for the holes and once you see the little indents in the trunk, simply drill straight down. You should probably put some sort of blanket or cover inside the trunk so you don't get all the burrs in it.
I wasn't too confident doin the drilling either, but I did 7 for my hoodscoop, and it fit fine. If you really really can't stomach the install, take it to someone who can do it for you. I will say $80 is a lot of cash for what they will do for you.
Good luck!
FM
ps. PICS WHEN YOU ARE DONE!
Old Mar 3, 2008 | 09:30 AM
mdg's Avatar
mdg
What is an auto-center punch? All I have are drill bits.
Old Mar 3, 2008 | 09:42 AM
06elnr's Avatar
06elnr
go to a hardware or carparts store and ask for one. it is a tool that looks kinda like a short fat pencil with a long lead...lol. what it does is, you put the sharp end on the center of the spot where you want the whole and you push it down and it makes a pop sound. then you have a small dimple to start drilling so the drill bit does not "walk" on you.
Old Mar 3, 2008 | 09:47 AM
DarkFireGT's Avatar
DarkFireGT
Guess you didn't want to trade? I had responded to your other thread.
Old Mar 3, 2008 | 09:48 AM
offrdmania's Avatar
offrdmania
An auto center punch is just a spring loaded center punch. You can get them at most stores that sell tools. I got mine at Harbor Freight for about $2.00. http://www.harborfreight.com/cpi/cta...Itemnumber=621 Be sure that once you punch the spot for the hole you start with a much smaller bit than the hole calls for. Once you have that hole drilled then you can come back with the bigger bit. It is a good idea to put a blanket or piece of cardboard down in the truck to catch the drillings. Otherwise you will just have to vacuum your trunk
Old Mar 3, 2008 | 11:47 AM
mdg's Avatar
mdg
I appreciate all of the information, will hopefully be doing the installation this weekend.
Darkfire GT - I received your message, thanks for the offer but I'd like to hold on to the same trunk.
Old Mar 3, 2008 | 02:26 PM
157dB's Avatar
157dB
Cut & Paste Expert
Be sure and use a drill bit designed for steel and not one
of those cheap ol wood bits that will corkscrew thru the
body panel distorting it. They are sharpened at different
angles and the wood bit ius just for wood. Get a HSS bit.
Drill a small pilot hole the same size as the web on the
drill used for the desired finished hole size.
Paint the raw metal edges with touch up paint.
Old Mar 3, 2008 | 02:41 PM
deekum1627's Avatar
deekum1627
i would def place tape over where your goin to drill then use a punch so you dont slip when you drill
CMcNam
Oct 30, 2022 11:40 PM
jwog666
Dec 27, 2021 08:09 PM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
jink21
Sep 3, 2015 11:04 AM
Nurdyguy
Aug 21, 2015 10:23 PM
