Battery Problem
Old Mar 3, 2008 | 09:14 AM
SemperFi789's Avatar
SemperFi789
Default Battery Problem
So my car isnt really starting, every time I want to turn it on i need a jump. I took it to advance auto parts and they did a "diagnostic" on the computer and the computer found nothing. We looked at it and the light inside the battery was red and the battery appeared to be leaking battery acid. My question is will this be covered under my warranty (2006 w/ 17900 m) and also could this have been caused by my after market sound system. Thanks in advance
Old Mar 3, 2008 | 09:28 AM
hammeron's Avatar
hammeron
Default RE: Battery Problem
it might be covered under warranty and
it might not.
you didn't mention the alternator, so keep
in mind the possibility of a weak charging
system
Old Mar 3, 2008 | 02:00 PM
rogan01's Avatar
rogan01
Sounds like it is definitely a bad battery - leaking acid. Usually, batteries are pro-rated based on how old they are - at Sears, you get a new battery if it fails within the warranty period for $1 - not sure about Ford though. Best thing is to call the dealer and ask the service department. Good luck.
Old Mar 3, 2008 | 03:55 PM
Qusus's Avatar
Qusus
This should be 100% covered by the 36,000 3 year bumper to bumper warranty. The dead battery problem is notorious, I've had it myself.
Old Mar 5, 2008 | 09:17 AM
SemperFi789
ORIGINAL: Qusus
did you have an aftermarkert sound system? i have a bad feeling that theyre going to resort to that and say that its my fault
Old Mar 5, 2008 | 09:26 AM
lukas77's Avatar
lukas77
Take it to the dealership for a new battery. There won't be any warranty issues. If the battery is leaking acid then it has nothing to do with your sound system.
Old Mar 5, 2008 | 09:42 AM
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: lukas77
Unless it was damaged during the audio installation. []
Batteries dont just start leaking acid for no reason.
Old Mar 5, 2008 | 10:52 AM
Kevjud's Avatar
Kevjud
I would get it changed as soon as possible. You don't want the battery acid to start corroding components inside of your engine compartment.
Old Mar 5, 2008 | 04:55 PM
SemperFi789
thanks guys, im taking it to the dealer when i get home from school since i have spring break this following week
Old Mar 5, 2008 | 06:10 PM
PennState's Avatar
PennState
Yeah im pretty sure its covered under warranty. I had battery problems before.
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
Art161
Sep 9, 2015 10:33 AM
Mobiusone stang
Sep 7, 2015 08:46 PM
