HELP!! Bleeding the Hydraulic Clutch
I just installed my level 2 Steeda clutch and I replaced the release clyinder. Now everything is back together and I need to bleed the hydraulic, except the valve is in an extremely hard to reach spot.
Anyone have any tips or an easy way to bleed this hydraulic clutch?
Has anyone perfomed this? How difficult was it?
Thanks in advance
Thanks in advance
RE: HELP!! Bleeding the Hydraulic Clutch
A hand held vacuum pump (i.e. Mity-vac) won`t make the bleeder any easier to access but it will minimize the number of times you open/close the valve. Just make sure you have plenty of teflon tape on the bleeder screw threads, otherwise air can seep past the threads and make you think there is still air in the system
The hydralic line going to my bleeder came loose during my header install...the crappy part is I have to replace the line and the bleeder because it comes all in one piece...its very hard to get to and its a PITA...however from what I have read you are supposed to pump the air from the resevoir and the brakes and clutch use the same resevoir...I haven't seen the device, but you are supposed to hook it up to the resevoir I believe and then you are able to pump the air from the system...I'm sure someone can chime in here though with a better explanation...
I'm not at home to look at the resevoir, but it may be possible to bleed air from it.
However, the hydraulic fitting on the tranny has a valve but it rests between the frame of the car and the side of the tranny. It looks near impossible to open and close the valve with a wrench.
And as 99flhr suggested, this valve may have to be opened and closed several times.
ORIGINAL: Hunt247
By just pumping the pedal I assume the air will travel back to the reservoir and not into the brake lines since it shares the same master clyinder?
junior04
09-28-2015 10:53 AM
