Tires to fill wheel well - Any advice?
#21
RE: Tires to fill wheel well - Any advice?
My 19's are still on order so I haven't driven them yet, but I thought they were a goodmiddle optionfor creating an aggressive look while still preserving some side wall for a better ride. I too live in New England and know first hand how crappy the roads are [:@]
I'm afraid if you go with 18's the look won't quite be as aggressive as you were hoping for.
#22
You could always go this route! However, I think it will remove the practical part of the equation.
I think you could go to a 295/45/18. It would give you a tire height of 28.31. You would need to get the rev/mile changed in the tune to about 730. Not sure how that would look or if it would cause a problem. Just a thought.
#24
ORIGINAL: Margarita Girl
So there isn't really a tire option to fill the wheel well?
Unfortunately your options in that size are severely limited.[:'(]
#25
The selection of 19's is definitely less than 18's and 20's, but I did find quite a few wheels at 19" once I started looking around. I found that lakeshore wheel and tire had quite a few, as well as a few other sites.
Good luck!
Good luck!
#26
The perfect size is....... 275/45/18
They are 27.74" tall.... about 1/2" taller than stock. They will look great!
I like these http://www.onlinetires.com/default.a...&tid=24686
#27
Is the tide gonna reach my chair?
ORIGINAL: moosestang
You want to be looking for a 255/50/18. That should give you close to 28 inch diameter.
I'm going to do some research on what tires are available.
#28
ORIGINAL: PLstang
275/40/18 et 24
[IMG]local://upfiles/50298/139E3ECCDEB8461986B1379B53A4B48F.jpg[/IMG]
[IMG]local://upfiles/50298/C0C73DFFBA5E43AFA979F5D7BC3E8786.jpg[/IMG]
mungodrums
10-07-2015 04:01 AM
mungodrums
Suspension
09-07-2015 07:22 PM
