Jack Stands on SubFrame Connector
Is it okay to put the jack stands on the subframe connector? I want to get some more room downthe center of the car, and just putting the stands on the front crossmember only give about 1-1/2 feet of space between them.
Also, what is the proper technique to getting all 4 wheels off without any problems? Which end should go up first. I have read someone that brought the rear up haf ay, then the front full, then the rear end to match. Does this sound right?
Thanks,
Sean
Thanks,
Sean
RE: Jack Stands on SubFrame Connector
Ive jacked up cars from the front first, from the rear first, never given any thought to it and never seemed to make any difference... Ive put jack stands under the frame, rear end, control arms, subframe conns, you name it...
ORIGINAL: ajaibr
Always ensure your jack stands will support the weight you are putting on them... and I always leavemy hydraulicjack near where I am working under the car-not supporting anything -but just in case the jack stands fail. You can never be too safe when working under a car.
My dad had a grease pit put in his garage - unfortunately he's about a 14 hour drive from my house.
Martin
Here are the recommended jack points from Ford.
Notice how the rear end pumpkin is NOT one of them.
[IMG]local://upfiles/69445/33A5417CA6634CAF8D79AA64ABEB8E63.jpg[/IMG]
ORIGINAL: 157db
Martin
ORIGINAL: mhconley
I have yet to jack up my Mustang but the diff is one of the first places I would expect to be able toput a hydrolic jack. Would using it cause any damage? Why is it not recommended?
Martin
ORIGINAL: 157db
Martin
the axle tubes are notaffixed goodenough to the pumpkin to support
the vehicle weight.
ORIGINAL: GidyupGo
Think about it for a spell.
response and by the time I posted
you had said the same thing.
ORIGINAL: ajaibr
The axle tubes aren't affixed good enough to support the vehicle weight? I've never heard that one... LOL
Apply some mechanical physics to it.
The weight of the vehicle is normally
on the two springs that are way out towards
the ends of the axle tubes near the tires where
the weight is transfered to the ground. Not much
leverage there to effect the axle tubes where
they go into the pumpkin. Not take that weight
thats equally divided up between the two rear
tires and applyall of itto the center of the axle assembly
and there is a chance the axle tubes will bend down
under the load and greater mechanical advantage from
the spring mounts being so far out on the tubes.
jwog666
12-27-2021 08:09 PM
09-17-2015 07:57 PM
09-08-2015 11:50 AM
