positive terminal
Old Mar 14, 2008 | 12:38 PM
Joolander's Avatar
Joolander
Lord High Protector
Default positive terminal
ow do I remove the positive connector of the battery? All it says in the manual is to remove it
Old Mar 14, 2008 | 12:55 PM
GidyupGo's Avatar
GidyupGo
Default RE: positive terminal
What are you trying to do? Usually, one would remove the neg termal first to cut down on an arc.
Old Mar 14, 2008 | 01:32 PM
Joolander's Avatar
Joolander
Lord High Protector
i did that, I'm just trying to clean the terminals because the positive one is corroded enough to look like it has brigh blue-green moss on it, and i want to clean it thoroughly
Old Mar 14, 2008 | 01:44 PM
GidyupGo's Avatar
GidyupGo
Well, a wire brush works well or one of those twisty terminal cleaners. I use baking soda in water or a little Coke on the terminal to neutralize any acid.
Old Mar 14, 2008 | 01:55 PM
Joolander's Avatar
Joolander
Lord High Protector
its aleady neutralized, I'd just like to get under there to make sure
Old Mar 14, 2008 | 06:47 PM
Aziraphale's Avatar
Aziraphale
I can't remember if you have to remove both bolts or just one but then it should just slide off.
Old Mar 14, 2008 | 07:01 PM
Joolander's Avatar
Joolander
Lord High Protector
ORIGINAL: Aziraphale
that's what I thought but it doesn't...
maybe mine is seriously corroded on there?
Old Mar 14, 2008 | 07:08 PM
Aziraphale's Avatar
Aziraphale
Interesting. Whenever I've had difficult ones in the past I twist it side to side a whole lot to losen the clamp up and it will eventually work its way up. Give that a whirl because I think once both clamps are undone, it is ready to come off.
Old Mar 14, 2008 | 07:40 PM
Joolander's Avatar
Joolander
Lord High Protector
i did try that, as it has worked for me in the past (not on the stang, though)
maybe I'll be a jackass and take it to the dealer and have them do it? i mean, i did nothing to make the terminal do this...
but I don't wanna be the "change my battery for me, and also armorall my dash because I'm lazy" guy
Old Mar 14, 2008 | 08:03 PM
Aziraphale's Avatar
Aziraphale
LOL, I got nothing man. Try prying it up with something? Either that or take it in and let them break it.
