NEEED HELP ASAP!
Old Mar 14, 2008 | 06:28 PM
forrestgump's Avatar
forrestgump
Default NEEED HELP ASAP!
Im setting here and ive almost done uninstalling my old CD player but I dont know how to remove the air conditioning control unit I see where the electrical connecters are holding it in and its a tight sqeezy toget them but I dont see release points especially on the bottom 2! Please help previous pics topics write ups would be nice, I went to taco bill's but I didnt see the write up on removing this part!
Old Mar 14, 2008 | 06:55 PM
partsbill's Avatar
partsbill
Default RE: NEEED HELP ASAP!
should come right out, only 4 screws holding it in.
Removal and Installation
[ol][*]Remove the center instrument panel finish panel. Remove the 4 climate control assembly screws.[*]Remove the climate control assembly.[*]
NOTE: Be sure that all climate control assembly electrical connectors are securely fastened before installing the center instrument panel finish panel.To install, reverse the removal procedure.[/ol]
[IMG]local://upfiles/31978/2270EA0DDCAF412EA4F0A1A8866B39C1.gif[/IMG]
Old Mar 14, 2008 | 07:00 PM
Aziraphale's Avatar
Aziraphale
If you're trying to remove the electrical connectors, you need to slide the gray retaining clip down and the connnectors will come out. On the ones that don't have a grey retaining sliding clip, it should just be clipped in. You'll need a flat head screw driver and to pry down to get over the retaining clip.
Old Mar 14, 2008 | 07:12 PM
smythge's Avatar
smythge
ORIGINAL: Aziraphale
Don't pry on the grey retaining clip it willbreak! Justtake a small flat head screw drive and just below the top of the clip push in and retaining clip will release allowing you to easily release it.
Old Mar 14, 2008 | 08:54 PM
forrestgump
Thanks guys looks I got the old CD player out and plan on installing the new one tomm. All the help is much appreciated.
Nick Oliver
Oct 17, 2018 04:22 AM
DJ Piner
Sep 30, 2015 03:03 PM
fireboss343
Aug 21, 2015 06:25 AM
kirk35
Aug 17, 2015 08:42 PM
TraumA 187
Nov 7, 2004 03:26 PM
