How much dynamat is enough?
Old Mar 15, 2008 | 12:37 PM
CroDalmatinac's Avatar
CroDalmatinac
Default How much dynamat is enough?
To do both doors, the rear seats area and the trunk? I don't want to order too much. How many feet, is what I'm looking for. Thanks!
Old Mar 15, 2008 | 12:42 PM
157dB's Avatar
157dB
Cut & Paste Expert
Default RE: How much dynamat is enough?
It really depends on how you cut it and how its applied.
Its not like painting where you can pre figure the amount
of paint needed.
[IMG]local://upfiles/69445/58A1E56CB2C84C3999E7F599D62D4CFB.jpg[/IMG]
Old Mar 15, 2008 | 06:12 PM
Briscoe's Avatar
Briscoe
did all that dynamat help alot? looks like a lot of work, and do you do the roof and firewall, were do you stop?
Old Mar 15, 2008 | 06:46 PM
Shard Phoenix's Avatar
Shard Phoenix
Just depends on what your looking for, if you just want some high powered door speakers and less vibration then the door is enough. If you want to reduce cabin noise then some other areas will be neccasary. A little google research will yeild a lot, some area's are far more effective than others to dynamat, for instance the roof yields more effectiveness since there is next to no sound deadening beneath the headliner, but the floor has quite a bit between the factory carpeting and factory sound deadening (though its no where near dynamat effective). Doors will be more effective than the rear passenger compartment etc. Whats your goal?
Old Mar 15, 2008 | 07:16 PM
06GT4RAD's Avatar
06GT4RAD
50 sq ft should be plenty.
Also there are plenty of other alternatives that cost less.
69FB
Aug 18, 2015 08:50 PM
nicarc369
Jul 19, 2011 04:52 PM
06stangGT
Aug 6, 2007 01:09 PM
richmod
May 3, 2007 12:01 AM
Azure
15
Jan 24, 2007 12:46 AM
