How To Remove Passenger Airbag?
ORIGINAL: 1morepart
go ahead and call the local ER, and tell them you decided to endanger a passenger's life...then get Jonny Cochran!
ORIGINAL: 1morepart
2. Jonny Cochran passed away years ago
I just did mine like a month ago, just make sure the battery is disconnected for like 15 minutes. It's not that difficult, drop the glove box first though, makes it that much easier. Should be 4 screws for the glove box, then 2 screws for the airbag. Disconnect the harness, then push the airbag assembly out, there are a bunch of tabs so it will take some force. Don't pull on the dash trim, make sure you push from inside the dash so you don't damage the aluminum trim. It's easy.
Ford installed an automatic release for the passenger side air bag. The switch is mounted in the front bumper. If you hit the bumper hard enough into something solid, the air bag will pop out all by itself!
lol I wont sue you cause Ill prolly be in shot gun when you rearend soembody . Hey I took my rear seats out today and DONT buy that delete kit we are going to makeour own dammitt, you hear me batman Im talking to you. Its so dam easy can do it for I bet like $40 then you can give me the extra 100 you were going to spend so I can buy sleeping pills. didnt go to bed again last night.
http://iihs.net/fsm/?dir=489&viewfil...0Indicator.pdf
Deactivating Air Bag System
All accessories OFF
IGN SW OFF
Remove RCMF17 SJB
IGN SW ON
Verify air bag indicator stays on for more than 30 seconds and does not go off
IGN SW OFF
Disconnect Negative Battery Cable
Wait 1 minute
Replace Air Bag
Reactivating Air Bag System
IGN SW ON
Replace RCM F17
Connect Negative Battery Cable
Prove OUT SRS
All accessories OFF
IGN SW OFF
Remove RCMF17 SJB
IGN SW ON
IGN SW OFF
Wait 1 minute
Replace Air Bag
IGN SW ON
Replace RCM F17
Prove OUT SRS
Thanks for the info but I just finished the swap and everything went smoothly, minus when I took out my airbag and it hit me in the head and cut my finger open, I didn't realize how much weight it had to it. Lesson well learned [:'(]
jwog666
Dec 27, 2021 08:09 PM
