Strut Tower Brace Problem...
Old Mar 22, 2008 | 02:39 PM
DeStonn's Avatar
DeStonn
Default RE: Strut Tower Brace Problem...
Scrap it
Old Mar 22, 2008 | 02:40 PM
Going for broke's Avatar
Going for broke
Screw on some nuts on the strutstuds first then install the brace I bet it will give you the clearance neccesary.
Old Mar 22, 2008 | 02:45 PM
DeStonn's Avatar
DeStonn
^ or do that
Old Mar 22, 2008 | 03:42 PM
2cokeman's Avatar
2cokeman
Defective for sure, happened to me with a BMR brace
Old Mar 22, 2008 | 03:46 PM
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: Going for broke
And defeat the whole purpose of having the brace. [:'(]
It really needs to be bolted firmly to the shock tower,
not spaced up on nuts to provide any worthwhilebracing.
Old Mar 22, 2008 | 04:08 PM
Going for broke
ORIGINAL: 157db
it won't be any weaker between two nuts then it would be mounted next to the strut tower. The bottom nut will tighten to the strut tower thus making it no weaker for support.In a perfect world thebrace would actually use all four bolts to secure it squarely above the strut tower and the bolt would go through the actually tubing not a welded on tab. That piece is more for show and not go. He has asked for suggestions and I offered one. [sm=icon_cheers.gif]
Old Mar 22, 2008 | 04:34 PM
nofear's Avatar
nofear
Id give them a call up and double check what clearances they have for their strut braces.
I haven't seen the engine cover but could u file the bottom down for that extra clearence ? .... something to look into
id personally just buy a better quality piece
Old Mar 22, 2008 | 04:45 PM
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: 157db
it won't be any weaker between two nuts then it would be mounted next to the strut tower. The bottom nut will tighten to the strut tower thus making it no weaker for support.In a perfect world thebrace would actually use all four bolts to secure it squarely above the strut tower and the bolt would go through the actually tubing not a welded on tab. [sm=icon_cheers.gif]
If it had mounting holes instead of mounting slots, it might work
but it would look jerry rigged and that throws the appearance
part of it out the window also.
So double negative on that strut tower brace. [:'(]
baddog671
Jul 26, 2016 01:20 PM
guitarman376
Oct 11, 2015 01:47 AM
allenmaty
Sep 24, 2015 09:17 AM
warwickbass
Sep 20, 2015 04:51 PM
Sep 16, 2015 07:53 PM
