Lowerd Rear Higher on one side
I had Lowerd My Car with Eibach Pro Kits and noticed at the rear that one side was higher than the other. I payed it no mind, and now after about six months, I decided to take another look at it and its still the same. About a 1/4" to 1/2" difference in height, only now it has started to bother me......How do I fix this problem?
RE: Lowerd Rear Higher on one side
Thanks for both your replies....No.....Its came with stock panhard bar...but not adjustable
.......is that all I need to fix that? I thought the panhard was for right and left alignment....
There is your prob. Here is a link to the one i bought. This will solve your problem.
http://stangsuspension.com/store/com...idproduct=1103
First, check you alignment of the rear axle(side to side ).Then I would see if one of your shocks is blown, causing it to sit lower. The I would see if they installed one of the springs up side down.
Dragonus18
09-09-2015 01:21 AM
