Strut Tower braces
Old Mar 29, 2008 | 05:28 AM
NJBLK07GT's Avatar
NJBLK07GT
Default Strut Tower braces
Looking to add one to my stang in the near future. I have the factory engine cover and I'm looking for input from fellow owners out there on which fits the best. If you have one please chime in with which one and any pros or cons on it and the install.
Thanks
Old Mar 29, 2008 | 07:16 AM
2cokeman's Avatar
2cokeman
Default RE: Strut Tower braces
I had the BMR brace with the factory plenum cover in my 07 GT and it fit perfect!
Old Mar 29, 2008 | 10:45 AM
oh6ponygirl's Avatar
oh6ponygirl
Agent 47 makes two versions, one of whichis for those with the cover. Its chrome moly I believe and attaches to all 4 strut bolts not just 2 and has the ends fully boxed...but of course its more expensive than all the rest except steeda's blingy show piece with pointless rod ends. I'm pretty sure this is the one I'll be going with when I pull the trigger on one.
Old Mar 29, 2008 | 11:44 AM
Orion_240's Avatar
Orion_240
you might want to check out this thread:
https://mustangforums.com/m_4842182/tm.htm
you could go from successfully trying to clear the plenum cover to not being able to close your hood![:@]
Old Mar 29, 2008 | 01:02 PM
Stkjock's Avatar
Stkjock
Retired Mod
steeda's fit - the V6 model clears the cover (they may have adjusted the V8 versoin too by now)
Old Mar 29, 2008 | 01:03 PM
VistaGT's Avatar
VistaGT
Steeda fits and looks GREAT
Old Mar 29, 2008 | 01:21 PM
Joolander's Avatar
Joolander
Lord High Protector
I like the style of the ones ford put on the 08 Bullitt.i was thinking of making a plaque to put on the STB with "GT/CS number XXXX" and the build date on it
but i gotta find one that has room for the plate, will clear the OEM plenum cover, and is low enough to fit under the stock hood
its tough
Old Mar 29, 2008 | 07:03 PM
swoosh's Avatar
swoosh
Got the Granatelli GT Dual Strut brace for street use. Got it b/c it goes over all of the boltson the towers. Seems like it would clear the plenium cover, but don't have one, so I cannot confirm.
Installed it while the car was on flat ground. All I needed was a ratchet and socket.
Whether it is usefule or not I can't say, but it does pretty-up the engine compartment
baddog671
Jul 26, 2016 01:20 PM
guitarman376
Oct 11, 2015 01:47 AM
allenmaty
Sep 24, 2015 09:17 AM
warwickbass
Sep 20, 2015 04:51 PM
Sep 16, 2015 07:53 PM
