How do I remove the window wipers?
Old Mar 31, 2008 | 10:40 AM
CroDalmatinac's Avatar
CroDalmatinac
Default How do I remove the window wipers?
I mean the whole unit, not just the blades. I need to remove them to install my CDC nozzle removal kit and the kit suggests using a hammer but I can't get to it due to the hood. I tried pulling but it won't budge...
Old Mar 31, 2008 | 11:19 AM
svfetter's Avatar
svfetter
Default RE: How do I remove the window wipers?
I know exactly what you are talking about. I removed mine from my Roush due to not driving in rain. I could not get mine to budge at first either.
I went to the parts store and got a small gear puller. Still did not want to move. So I loaded up the gear puller with a fair amount of force and then took a heat gun and heated the wiper arm where it surrounds the shaft. After about 20 seconds of heating it popped. Just lift it off at that point.
Seems others have had a much easier time than me, but mine were a bear. Good Luck.
Old Mar 31, 2008 | 11:41 AM
noonyb's Avatar
noonyb
A gear puller is the way to go. A power steering pump puller is the right size. Also taping the shaft with a hammer after removing the nut may loosen it.
Old Mar 31, 2008 | 01:19 PM
GidyupGo's Avatar
GidyupGo
There used to be a clip you had to push to release them. Even after doing that. they were stuck on good sometimes. Don't know about these but something has to keep them on besides a tapered shaft.
Old Mar 31, 2008 | 01:29 PM
GidyupGo's Avatar
GidyupGo
http://iihs.net/fsm/?dir=471&viewfil...ivot%20Arm.pdf
Or you could try this.
cr620
Oct 3, 2022 10:18 PM
jwog666
Dec 27, 2021 08:09 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
