Fuel Fill Problem Poll
Old Apr 1, 2008 | 06:48 PM
DoctorQ's Avatar
DoctorQ
Default Fuel Fill Problem Poll
Doing some data gathering on the S197 Fuel Fill (premature nozzle shutoff) problem. Ford has replaced my entire EVAP emissions system, and nozzle still shuts off at 1/2 tank (only fills driver's side saddle tank). Every now and then, if I flip nozzle between 2 and 3 o-clock position, it will fill all the way up.. but that is not the answer. Anyway, Ford has agreed to send out an Engineer to evaluate my car. I'd like to take back some data showing Ford this is not an isolated problem. Your input is greatly appreciated:
Old Apr 1, 2008 | 06:53 PM
08Eleanor's Avatar
08Eleanor
Default RE: Fuel Fill Problem Poll
Sometimes I can only put in 10 gallons when my car says empty, but then the gauge goes to full after a little bit of driving. Doesn't make much sense to me...
Old Apr 1, 2008 | 06:55 PM
kngdaka's Avatar
kngdaka
First week I had the car I had the problem on my first fill-up (actually overflowed). Theres a certain way it's gotta go in I realized, and I haven't had an issue since.
Old Apr 1, 2008 | 07:02 PM
maniacmikey's Avatar
maniacmikey
We are not allowed to pump our gas in Oregon but I have noticed that I have a problem with the nozzles that cover the entire opening to the fuel filler. Also if the station is not on level ground it seems to have trouble filling. When it clicks off you can heara gurgle coming from the filler.
Old Apr 1, 2008 | 08:47 PM
odiaz's Avatar
odiaz
in 3 years, I've only had this problem less then 5 times.
Old Apr 1, 2008 | 09:03 PM
rmssch89's Avatar
rmssch89
I seem to only get this problem in California with the really large nozzles they have there.
Old Apr 1, 2008 | 09:13 PM
acascianelli's Avatar
acascianelli
I've had it happen to me before, not that often. I usually just stop filling and leave the gas station.
Old Apr 1, 2008 | 09:33 PM
vtmustangs's Avatar
vtmustangs
I have the problem only at certain gas stations but usually those stations have the lowest prices but def a problem but what can you do sometimes if you turn it then it will work.
Old Apr 1, 2008 | 10:03 PM
Kara's Avatar
Kara
I have this problem often!
Old Apr 1, 2008 | 10:35 PM
GidyupGo's Avatar
GidyupGo
Mine hasn't clicked off prematurly in a long time. I found a pump my GT likes at the Shell and I stay with that one.
