Tire Pressue Continually Dropping?
Old Apr 3, 2008 | 05:04 PM
157dB's Avatar
157dB
Cut & Paste Expert
Default RE: Tire Pressue Continually Dropping?
ORIGINAL: ensign_lee
K, n00b question: how do I check the valve stem?
Rouch, do ya need help puttin ya pants on in the morn also?
The valve stem is the little rubber thingy stickin out of the rim
and it has a cap on it. Dont confuse it with wheel weights which
look like little slugs of lead clipped onto the edge of therim to help
balance the tire/rim assembly. Back to the valve stem... Take the valve
stem cap off and squirt some soapy water into it. Bubbles means
its leaking. No bubbles means no leak. Be sure and replace the
valve stem cap when done to kep dirt out.
Old Apr 3, 2008 | 05:40 PM
ensign_lee's Avatar
ensign_lee
lol, k thanks 157db
Old Apr 3, 2008 | 05:49 PM
300GT's Avatar
300GT
ORIGINAL: 157db
Its called a flat. They happen sometimes.
There are places you can take your tire
and they can patch it for you. You dont
need to buy a new tire if they try and sell
you one.
Get out the ol soapy water and
spray some on your leaky tire and the
leak will appear as bubbles where the tire
is leaking air. No bubbles, no leak.
I would hop on the valve stem first if
no nails are readily visable upon inspection.
Unless the nail (assuming it's a nail causing this) is in the sidewall - then he might need a new one. A lot of places will only patch/plug if the nail is in the tread area. But as mentioned above, check the valve stem first.
Old Apr 4, 2008 | 11:01 AM
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: 300GT
ORIGINAL: 157db
you one.
Sorry I didnt spell it out to the last detail. I tried.
Any sidewall damage requires a new tire.
Carolina Man
Carolina Regional Chapter
35
Aug 7, 2017 10:52 PM
Gene K
Oct 21, 2015 11:37 PM
musnicki
Sep 23, 2015 07:11 AM
Sep 8, 2015 11:50 AM
zanemoseley
Sep 6, 2015 12:58 PM
