Agent 47 Strut Tower Brace
Mustang Strut Tower Brace - Agent47 GT Strut Tower Brace
Improve your ride with a great looking, rigid and lightweight Strut tower Brace from Agent 47. Each strut brace is made from a 1.25” O.D. chromoly tube which is tig welded to boxed structure on each end which are also tig welded.
These boxes use all four bolts on the strut tower to mount the brace solidly.
One look at one of these braces and you will see the design, fit, welds, and finish are second to none. They come in a black powdercoat and install time is less than 15 minutes.
Please note: If you have a Plenum Cover or Supercharger, check out Agent 47's Double Barrel High Clearance Brace
To check them out or to place an order just click below
Agent47 Strut Tower Brace fro SouthernMustangParts.com
If you purchase with the Agent 47 Retro Race Mirrors you can save an additional $50.00
http://www.southernmustangparts.com/...eal-p-365.html
Thanks
Ken
Thanks
Ken
RE: Agent 47 Strut Tower Brace
For those with a Plenum Cover or Supercharger we also have the Double Barrel Strut Brace as well...
This brace is very similar to the standard GT brace in that is uses chromoly tubes Tig welded to CR steel boxed structures. It is different because it uses two smaller 1” chromoly tubes bent for maximum clearance over the engine.
Thanks
Ken
Thanks
Ken
09-16-2015 07:53 PM
