TPMS / TUBE TRICK
TPMS / TUBE TRICK
Hy guys, I just want to know if anybody has actually tried the tube trick and if it works. And if there are any issues after a long term vehicle storage. I removed my sensors and put them in a tube but I cant try it yet because I have not received my new wheels and I'm debating if I should put them on the new wheels or just leave them in the tube.
Thanks to all who respond. By the way I'm waiting on the steeda ultralites.
[IMG]local://upfiles/83300/C77B0D7A931C486E9FF94CE16D9BAE57.jpg[/IMG]
RE: TPMS / TUBE TRICK
What's the big deal of installing them in your new wheels? The band kits are $17.90 each at AmericanMuscle. Just install them and you won't be messin' around with a tube that'll likely need to be pumped back up occasionally.
ORIGINAL: Aziraphale
...the motion is what activates them so it might not work unless the tube shakes around.
+1 in getting new bands, they're cheap.
But what if I have a bad TPS sensor? Can I get used sensor and just remove the old one and throw in the new one? or do they need some type of reprograming?
I hate TPS !!!!!!!![:'(][:@]
ORIGINAL: MexGT
yes the tube trick will work, they will go into sleep mode after not sensing motion for a while and not trigger a tpms fault because the pressure was all right when they went into sleep mode, i read somewhere that you have to be going like 20mph to wake up the sensors,
