Air Condition Delete
Old Apr 15, 2008 | 12:53 PM
jlaurens06gt's Avatar
jlaurens06gt
Default RE: Air Condition Delete
I believe that leonardracing had a shorter serpentine belt available. I just checked his site and it seems to be down. If I recall correctly he uses it when at the strip to reduce parasitic loss and free up power to the ground. He then swaps it out after racing. I think he mentioned that it is a real simple procedure.
Old Apr 15, 2008 | 01:32 PM
ohfiveride's Avatar
ohfiveride
the question is...do you really need power streering?....
Old Apr 15, 2008 | 01:48 PM
jlaurens06gt
even further:
easy = spare, rear seat,extra fuel, windshield washer fluid...
mildly radical= center console,passenger seat, lightweight radiator support....
a little too far? =carpeting,radio and speakers,windows,glovebox/manuals, visors! antenna delete! mirrors!
GOOB/Going to the track andEVERYTHING MUST GO!!!!!
Old Apr 15, 2008 | 04:36 PM
157dB's Avatar
157dB
Cut & Paste Expert
You forgot helium in the tires to reduce unsprung weight.
Old Apr 15, 2008 | 04:42 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: ratnacage
If I had a list of top ten worst mods, this would be #1. No gain of any sort and you'll kill the resale/trade-in value (the AC system will eventually fail fromnon-use due to seals drying out and internal corrosion - then you're looking at probably $700+ to restore it). I can think of a lot of other ways to get the engine to spin upfaster, plus when the compressor is not on, there is virtually no drag. Plus don't forget you probably use the front defrost function which would be disabled without the compressor. I'll bet driving in the rain in the middle of summer would pose some problems - think about it.
All pain, no gain.
...actually, if you were a really hard-core track-only racer, the only gain would come from weight savings by completely removing the AC system.
+1 unless you completely remove the A/C system, don't bypass it. You have to remember the evaporator core also runs in front/behind the Radiator. Non-use of the A/c system could lead to corrosion that eats throught the core and into the radiator.
Old Apr 15, 2008 | 05:22 PM
Kara's Avatar
Kara
People get to obsessed over ditching everything! I prefer power steering and a/c
Old Apr 15, 2008 | 05:30 PM
99flhr's Avatar
99flhr
ORIGINAL: Derf
I have to go with "no" here, theEVAPORATOR is in the dash firewall area. Yes, the CONDENSER is in front of the radiator and non usecan lead to internal corrosion. As for that corrosion leaping over and eating your radiator. Not going to happen.
Old Apr 15, 2008 | 07:52 PM
Bluestar's Avatar
Bluestar
If the A/C delete, enabled my car to do the quarter mile in 8 seconds, I still wouldn't do it.......I need my creature comforts.
jwog666
Dec 27, 2021 08:09 PM
svfetter
Oct 5, 2015 11:39 AM
b8checker
Sep 30, 2015 07:11 AM
Sixer4Life
Sep 28, 2015 07:05 AM
treesloth
Sep 28, 2015 07:03 AM
