New Dyno Numbers & Shiftlight Installed
Old Apr 9, 2008 | 06:50 PM
sailing220's Avatar
sailing220
Default RE: New Dyno Numbers & Shiftlight Installed
ORIGINAL: vocoat
Can i correct that without going to larger injectors ?
Well, you need more fuel...the injectors you have right now aren't able to provide sufficient fuel.
Old Apr 9, 2008 | 06:57 PM
onederful100's Avatar
onederful100
those are nice numbers. but the a/f would concern me.
TJ's Avatar
TJ
I would never run 12.7 afr if your going to push maybe 12.0 12.1 but that’s it. I would think with that kind of rwhp 60lb injectors would be the way to go I would not run 39lb injectors with that kind of rwhp. What mafs are you using for that kind of rwhp? Because if you peg out your mafs (at 525whp) say goodbye to your motor. Interesting to see what kind of numbers the Whipple will do an 11.7 afr running 12.7-13lbs with the Whipple post if you get a dyno running a 11.7afr.
Good luck and nice numbers in any case!
Old Apr 9, 2008 | 07:14 PM
TJ's Avatar
TJ
You the more I think about it I kind of find it hard to believe the tuner would run a 12.7 afr (any tuner imo)I am thinking its 11.7.
Old Apr 9, 2008 | 07:18 PM
PLstang's Avatar
PLstang
I'd be saving money for a short block. Just my opinion.
Old Apr 9, 2008 | 07:50 PM
Thurman's Avatar
Thurman
Nice numbers. But very scary.
Old Apr 9, 2008 | 08:00 PM
Bluestar's Avatar
Bluestar
I think you should consider getting Forged Internals, if you plan on keeping your car on the road. I'd be like this if it was mine....
Old Apr 9, 2008 | 08:06 PM
Vcoat's Avatar
Vcoat
I have been driving with setup for over three months now with no issues...I defitnetly will check into the Air Fuel ratio...Could it have been the way it was mesured ?..I believe they used the tail pipe sniffer
Old Apr 9, 2008 | 08:33 PM
brendend's Avatar
brendend
ORIGINAL: vocoat
with that afr and stock internals..... very ballsy.
Old Apr 9, 2008 | 08:48 PM
Ford_Dude's Avatar
Ford_Dude
1st go get some 60# injectors
2nd upgrade your fuel pump
3rd goget another dyno run with a per-cat sensor
and if its still 12.7'ish
then get a retune or forged inerds
