Parking brake
Old Apr 11, 2008 | 12:08 AM
sacrelli's Avatar
sacrelli
Default Parking brake
Hi,
I just got a 2006 Mustang. I am real protective of it right now and I know this seems like a dumb question but I would really appreciate it if someone would answer it. I accidently put on the parking brake on before putting the car into park tonight. When I realized it I took the parking brake off, and moved the shifter to from drive to park. I then proceeded to put the parking brake on. Did I do anything wrong here? I mean did a mess up anything? It is an automatic. I am new to all this so please be nice.
thanks
Old Apr 11, 2008 | 12:13 AM
MD07gtcs's Avatar
MD07gtcs
Default RE: Parking brake
No you will be fine I wouldnt worry about it at all.
Old Apr 11, 2008 | 12:16 AM
sacrelli's Avatar
sacrelli
thanks, I can finally relax. lol.
Old Apr 11, 2008 | 12:19 AM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
No worries but with any auto I never used the parking brake! Personal preference and good to use to lessen the chance of it not working when you need it! JMO J
Old Apr 11, 2008 | 12:24 AM
sacrelli's Avatar
sacrelli
ORIGINAL: mygt500
Hi,
So you recommend not using the parking brake unless I am on a hill, etc? Oh, and you also think that what I did tonight is OK for the car? I mean did I harm it in anyway?
thanks
Old Apr 11, 2008 | 12:28 AM
Rainson's Avatar
Rainson
ye,nothing wrong..dont scare to ask questions..u wont go wrong by asking any question here..
Old Apr 11, 2008 | 12:32 AM
AK_Kayaker's Avatar
AK_Kayaker
Actuallyto take the strain off of the parking pawl, you should be putting the parking brake on before putting it into park.
And most parking brakes that I have seen not working for from nonuse, and the cables rusted inside the outer housing.
Old Apr 11, 2008 | 12:34 AM
sacrelli's Avatar
sacrelli
hey, thanks guys. I feel better now.
Old Apr 11, 2008 | 12:37 AM
Burnsy's Avatar
Burnsy
actually, you did do something wrong.
Now 95% of the drivers out there have never heard of doing it this way, but this is the correct way to do it. I have to respectfully disagree with jason on this, as I use the parking brake on every vehicle, and actually especially on an auto.
Here's why.
There is no gear such as "park". "park" is neutral, with a parking pin. This pin slips into place when you put it into park, and slides into a hole that then keeps the car from moving. however, this parking pin can get pinched, and if used on a hill, it may not come out properly, and you could damage the transmission.
So, technically the proper parking procedure I have always followed with all vehicles is this:
Let vehicle come to complete stop on whatever ground you are on.
Shift to Neutral
Pull up parking brake all the way
Release Brake
Let Parking Brake Hold the Car
Then shift to Park
This way you will not pinch your parking brake.
And I know in many states, including CT, where I live, it is illegal to be parked without the parking brake engaged, so it is the law to use it!
Old Apr 11, 2008 | 12:40 AM
sacrelli's Avatar
sacrelli
ORIGINAL: Burnsy
Here's why.
Shift to Neutral
Release Brake
Then shift to Park
I guess my next question is, did doing it this way once damage the car?
thanks for your response.
