Parking brake
Old Apr 11, 2008 | 01:55 AM
  #21
sacrelli's Avatar
sacrelli
Default RE: Parking brake
ORIGINAL: howarmat
i know you are new to this....but dont bump a post at 230 in the morning when the post is only 3 down from the top......consider this a warning
Sorry, I didn't realize it was so close to the top. I just refreshed from the page and when I noticed there was not a response I wrote bump.
Old Apr 11, 2008 | 04:11 AM
  #22
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
You in no way offended me and I still have always NEVER used a parking brake on an auto except for special cases you mentioned (like on hills-uphill or downhill). This is what the forums are for as you know and it was JMO so take it for what its worth. I live in Michigan and have always lived in a level area not know for drastic hills or real steep driveways. I did know about the pin but guess have always put "much" trust that it wont fail....might be my bad one day but until then..... later Burnsy and welcome to the forum sacrelli J
ORIGINAL: Burnsy
actually, you did do something wrong.
Now 95% of the drivers out there have never heard of doing it this way, but this is the correct way to do it. I have to respectfully disagree with jason on this, as I use the parking brake on every vehicle, and actually especially on an auto.
Here's why.
There is no gear such as "park". "park" is neutral, with a parking pin. This pin slips into place when you put it into park, and slides into a hole that then keeps the car from moving. however, this parking pin can get pinched, and if used on a hill, it may not come out properly, and you could damage the transmission.
So, technically the proper parking procedure I have always followed with all vehicles is this:
Let vehicle come to complete stop on whatever ground you are on.
Shift to Neutral
Pull up parking brake all the way
Release Brake
Let Parking Brake Hold the Car
Then shift to Park
This way you will not pinch your parking brake.
And I know in many states, including CT, where I live, it is illegal to be parked without the parking brake engaged, so it is the law to use it!
Old Apr 11, 2008 | 04:49 AM
  #23
CrazyHorse0217's Avatar
CrazyHorse0217
There is a warning chime if you drive with the e-brake on. Didn't hear this?
Old Apr 11, 2008 | 04:55 AM
  #24
nascarjunkie1's Avatar
nascarjunkie1
Just use caution if you use your e-brake in freezing weather, becuase it might not release
Old Apr 11, 2008 | 09:37 AM
  #25
Norm Peterson's Avatar
Norm Peterson
ORIGINAL: Jersey Stang
A few nights ago, someone posted a different response about the parking brake. He said auto's should never use the parking brake because it causes uneven cooling to the rotors and pads. This could eventually warp the rotors. any response to that?
The tech on that is that if you've used your brakes hard and then parked the car without letting them cool down. Most normal driving isn't that hard, but mountain driving, high speed auto-X, and braking from 110-ish at the end of the drag strip can be. Needless to say, road-racing, open-tracking and canyon running is. That also implies something about [not] holding yourself at a full stop with the service brake if your driving has fallen into the realm of 'really hard braking' and you haven't cooled the brakes down.
What nascar posted is probably familiar to every driver who learned to drive in New England back in the 60's . . . along with cables that stretched and truly horrible activating mechanisms . . . caused one to mostly ignore the P-brake except when parking uphill/downhill or working on the car.
sacrelli - a little patience, please. Even under the best circumstances you shouldn't expect turn-around times of only 17 minutes and change. Let the little hand go one full trip around the clock, m'kay? You could also set your thread notification preference in your control panel to
Notify me whenever a message is posted
Norm
bradleyb
Nov 27, 2015 07:50 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
