Probably a Stupid Sequential Tail Lights Question
Old Apr 13, 2008 | 09:58 PM
ensign_lee's Avatar
ensign_lee
Default Probably a Stupid Sequential Tail Lights Question
Ok, so I've been looking at youtube videos of sequentials for a little bit now, but there's one thing I'm slightly confused on.
When both of the tail lights are flashing out...does that only happen when you have your hazards on? Or are they always doing that when you have your lights on?
If they only happen when you have your hazards on, they when it's dark out and you just have your "normal" lights on, they're still solid and normal, yes?
This is probably a very stupid n00b question, so thanks for the responses!
-ensign_lee
Old Apr 13, 2008 | 10:22 PM
acascianelli's Avatar
acascianelli
Default RE: Probably a Stupid Sequential Tail Lights Question
ORIGINAL: ensign_lee
You're correct on both.
Old Apr 13, 2008 | 11:16 PM
Centurion96's Avatar
Centurion96
Most all of the Plug-n-Play models have the brake light wire and the trigger wire for the control module tied together. The result is that when you press the brakes then both sides sequence once and then remain on. The control module has to see an OFF then ON condition to trigger. It won't sequence again until the brakes are released and depressed again. In turn signal mode the control module is seeing the on and off of the turn signal voltage either from a flasher (2005-2006) or from the PCM (2007-up). If you go to the WebElectic site, he has instructions on how to wire up the modules such that they only sequence on the turn signal and not the brakes. It requires cutting the trigger wire and then running new trigger wires from the PCM which were tapped into the front turn signal wires. That's the way mine are configured.
Old Apr 14, 2008 | 12:09 AM
ensign_lee's Avatar
ensign_lee
Thanks guys!
Ok, other stupid sequentials question: what is the difference between chase lights and normal sequentials?
I went to youtube to try to see the difference, but um...I can't see a difference?
Old Apr 14, 2008 | 12:31 AM
ensign_lee's Avatar
ensign_lee
Thanks guys!
never mind. Went to meter4it.com and saw an illustration of hte difference. It's hard to see with just the three bulbs, but I can see it now.
raleigh05GTO
Sep 4, 2015 07:09 AM
cbird1177711
Sep 2, 2015 08:51 PM
cbird1177711
Sep 2, 2015 04:12 PM
AMAlexLazarus
AmericanMuscle.com
Sep 2, 2015 08:59 AM
