Ideal shift points
Old Apr 16, 2008 | 08:47 AM
Croy9000's Avatar
Croy9000
Default Ideal shift points
Ok this is a newb question, I have never raced. How do you learn what the ideal shift points for your cars manual trans? I know some install shift indicators. And some come stock with indicators like the Shelby GT500 I think.
Any tips or resources to share?
Steve
Old Apr 16, 2008 | 08:52 AM
Wildmatt's Avatar
Wildmatt
Default RE: Ideal shift points
Shift 300 RPM before redline. That is when the throttle body begins to close.
Old Apr 16, 2008 | 09:21 AM
06Redfire3V's Avatar
06Redfire3V
I shift at 6700..
Old Apr 16, 2008 | 10:18 AM
Going for broke's Avatar
Going for broke
actually that will vary with every gear. In a nutshell, looking at a dyno graph you want to stay centered over the power peak. Since 1-2, 2-3, 3-4 and 4-5 aren't evenly spaced the IDEAL shift point will change for every gear. Very few vehicles make Peak power at redline. they usually crest several hundred rpm before redline. You would have to set up a spreadsheet with your ratios and a dyno sheet to know exactly.
Old Apr 16, 2008 | 10:20 AM
acascianelli's Avatar
acascianelli
I usually shift right at redline.
Old Apr 16, 2008 | 10:23 AM
Going for broke
In looking at a few charts I would say shifting a little before redline(5800?) in 1-2 and 2-3 and then wringing it out to 6200 or so would net you the fastest accelleration.
The first three gears are always closest together.
6700 is waayyy out there unless you have some cams.. Motor signs off well before that any dyno chart will show you that.
jwog666
Dec 27, 2021 08:09 PM
Thunderball
15
Nov 22, 2015 11:49 PM
flash_xx
Oct 16, 2015 07:23 AM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
