Stroker kits
Old Apr 17, 2008 | 09:12 PM
Joolander's Avatar
Joolander
Lord High Protector
Default Stroker kits
I heard a rumor that the 2010 stangs will have a 5.0 option, and that it would basically be our 4.6 but stroked out
I'm sure we all know the advantages of a stroker kit, what i would like to know is what are the disadvantages? I realize a custom tune would be a must
Old Apr 18, 2008 | 06:57 AM
Joolander's Avatar
Joolander
Lord High Protector
Default RE: Stroker kits
no one cares?
Old Apr 18, 2008 | 07:07 AM
Boss919's Avatar
Boss919
Maybe slightly less MPG?
Old Apr 18, 2008 | 09:41 PM
dlarge122878's Avatar
dlarge122878
Increased stroke makes the piston travel further up and down. Since the amount of time allowed for this movement is not increased, the piston speed increases with a stroked crank (piston must move a further distance in the same amount of time). This can sometimes cause pistons to wear more quickly.
Large increases in stroke can decrease an engine's ability to perform optimally at high rpm. Engines used at sustained high rpm usually will be better with less stroke and more bore.
Old Apr 20, 2008 | 02:19 AM
S281 E's Avatar
S281 E
^+1
This is THE biggest disadvantage with a stroker motor.
Old Apr 20, 2008 | 04:02 AM
1BAD3V's Avatar
1BAD3V
So what kind of power can we figure with a 5.0 stroker?
Old Apr 20, 2008 | 07:21 AM
lieu910's Avatar
lieu910
ORIGINAL: dlarge122878
All true, but pay attention to the word "can" when the topic of operating at high RPM.This depends on the rod to stroke ratio, and the level ofthese supposed high RPM's.
As it relates to the 4.6....a 3.75 stroker crank will not create any tangible disadvantage to the standard 4.6while operating in the upper RPM range. The 3.75 crank and .020 over bore will provide the 302c.i. This is the combo I am running and my car revs to 7,000 rpm without a problem.I have heard that the 3.80 crank is a tad on the long side for a desireable rod / stroke ratio.
Old Apr 20, 2008 | 08:14 AM
Joolander's Avatar
Joolander
Lord High Protector
doesn't saleens 302 engine use just the stroker to acheive the ci? or do they also bore it little? anyway, I heard that N/A ythat engine makes 390hp!!!
Old Apr 20, 2008 | 09:10 AM
lieu910's Avatar
lieu910
ORIGINAL: Joolander
The Saleen uses the 3.80 crank and no over bore.
Old Apr 20, 2008 | 10:55 AM
pascal's Avatar
pascal
S197 Section Modder-ator
I think the 5.0 Cammer for exemple,is bored, not stroked.
So there is different ways to get there.
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
flash_xx
Oct 16, 2015 07:23 AM
Drastang
Sep 30, 2015 03:48 AM
