Whipple 2.3L????!!!!
Old Apr 23, 2008 | 09:55 PM
57599grs's Avatar
57599grs
Default Whipple 2.3L????!!!!
Hey guys,
so i was thinkin about a whipple now and am getting cash together now??? anything to add??? did you guys like it??? did you have to put in a new spline???
Old Apr 23, 2008 | 10:34 PM
hammeron's Avatar
hammeron
Default RE: Whipple 2.3L????!!!!
good choice....call tousley ford and
also check out the site vendors.....
Old Apr 23, 2008 | 11:33 PM
57599grs's Avatar
57599grs
are you have any prbloems with yrs???
Old Apr 24, 2008 | 06:14 AM
Jus Cruisin's Avatar
Jus Cruisin
I think you'd better think about forged internals. You might as well get the rebuild out of the way now, otherwise your rebuild later will be more expensive.
Old Apr 24, 2008 | 06:59 AM
bmk's Avatar
bmk
depending on how much boost and HP numbers, you may want to get forged. the block should be fine with 450hp so long as you dont abuse the car
Old Apr 24, 2008 | 07:23 AM
ryanralston07's Avatar
ryanralston07
ORIGINAL: Jus Cruisin
+1 I got the HO kit for the whipple and wish I could throw on a 14 psi pulley for more power...or even a 12 psi pulley, but I don't wanna run the risk of blowing the motor. The 500hp kit (HO) is a complete kit and comes with everything you need...so does the 400hp kit, but trust me it's worth the extra $ to go with the HO straight up because once you get into boost and hear that pretty whine you can only want moreRight now I'm having to save for forged internals when if I had just done it upfront when the S/C was put on it probably would of saved a lot of $. I don't regret getting the Whipple, it's one the best kit out there for my cars IMHO because of all that comes with it and it's potential. You might want to buy some gauges though to monitor your engine and other performance aspects. I got the Triple Gauge Dashpod from Autometer and then got 3 gauges (Wideband A/F ratio, Electrical Oil Pressure, and a Mechanical Boost/Vacuum). You'll see that there are cheaper gauges like there is a mechanical oil pressure gauge that is much cheaper, but the electrical is the way to go because if you use a mechanical gauge you have to run an oil line into the cabin and well it that breaks you can only imagine how bad it'd be if the line broke lol.[:'(]
Old Apr 24, 2008 | 08:32 AM
hammeron's Avatar
hammeron
coming up on a year now and no
problems
ORIGINAL: 57599grs
Old Apr 24, 2008 | 09:16 AM
aclass's Avatar
aclass
ORIGINAL: hammeron
+1 Steve @ Tousley has been more than helpful. Highly recommended.
Old Apr 24, 2008 | 10:15 AM
moosestang's Avatar
moosestang
You don't need anything else, but you'll probably want a new clutch before long. Mine started slipping in 3rd gear.
Old Apr 24, 2008 | 11:35 AM
MustangGT0405's Avatar
MustangGT0405
+1 Steve at Tousley hooked me up
Granatelli Sales
Mar 21, 2016 06:16 PM
Bokeo
Oct 10, 2015 08:28 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
ShaneB26154
Aug 28, 2015 04:47 PM
