question about sping install
Old Apr 24, 2008 | 03:42 PM
VanWilder's Avatar
VanWilder
Default question about sping install
Ijust bought theBMR 2in lowering springs from a guy that really knows mustangs and told me that with my tire size (275/35/18)I wouldn't have to put on an adjustable panhard bar...I was just wondering what some of you guys thought of this...let me know.
thanks
Lance
Old Apr 24, 2008 | 03:51 PM
SuperSonic05's Avatar
SuperSonic05
Default RE: question about sping install
I think it more about how much you drop it not the tire size. I think you will need one after 1.5in. you could always install it then check the placement of the tires.
Old Apr 24, 2008 | 04:08 PM
157dB's Avatar
157dB
Cut & Paste Expert
It depends on the tire width,rim width, and backspacing.
Wider tires limits the amount of outside fender clearance
and any shift can cause trouble such as a 2" drop.
If its close, you need an adjustable panhard bar.
An Adjustable Panhard Bar is in your near future.
And also an adj. UCA is recommended to adjust
the pinion angle back to proper specs after the 2" drop.
Old Apr 24, 2008 | 04:45 PM
waykooljr's Avatar
waykooljr
You'll want to do your homework before making modifications to your suspension. A considerable drop is going to require other modifications; LCA relocation brackets, UCA for pinion angle adjustment and an adj.panhard bar for centering the axle. If you are lowering the front as well, you'll need to look into camber bolts or camber plates.
Check out the handling section, F1fan has posted A LOT of great intel concerning suspension modifications.
Old Apr 24, 2008 | 08:54 PM
Argonaut's Avatar
Argonaut
You can put the springs in without an adj PHB or any of that other stuff and see how it works for you, its not like anything is going to break. Yes it will affect your handling but that may or may not bother you depending on your style and use. I'll bet you'll want an adj PHB at a min though, with tires that wide and a big drop it is highly likely your left tire will be sticking outside the fender and the right tire...it might be inside the fender or just even.
Old Apr 25, 2008 | 10:42 AM
VanWilder's Avatar
VanWilder
thanks alot guys...i am going to eventually get the adj phb im just having money issues at the moment and was wondering if it was worth the time to put the springs in now or if i should just wait until i can get some more suspension work (adj phb, lower control arms, etc) as for wheelsize i have 18x10s on the rear...most likely i will wait until i can afford more so i can do it all right
Lance
Old Apr 25, 2008 | 11:37 AM
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: VanWilder
Lance
Its OK to wait as long as your tire(s) dont rub (get cut) the
fender lip during full suspension compression such as over bumps.
The rear endwill stick put of the drivers side with that much drop
(2") and an OEM length panhard bar.
drfister
May 3, 2018 10:38 PM
GimpyHSHS
Aug 29, 2015 06:30 PM
toastintx64
Aug 29, 2015 05:12 PM
whatsup62
Aug 29, 2015 01:25 PM
Shifty Magoo
Aug 25, 2015 03:08 PM
