Steeda Underive Pulleys
Old Apr 25, 2008 | 09:13 AM
rshamekh's Avatar
rshamekh
Default RE: Steeda Underive Pulleys
thanks, good to know.
Old Apr 25, 2008 | 09:14 AM
Daniel60's Avatar
Daniel60
Old Apr 25, 2008 | 09:16 AM
ThumperMX113's Avatar
ThumperMX113
I did reinstall the factory bolt though. I believe the bolt can be used twice so you will be fine. Just follow Steedas instructions you wont have a problem. Just make sure you get the Chrysler Harmonic Balancer Puller for removal of the factory pully.
Old Apr 25, 2008 | 09:30 AM
rshamekh's Avatar
rshamekh
I rented a puller from advance, and I have a basic tool kit, so I guess I should be fine.
Old Apr 25, 2008 | 09:32 AM
Daniel60's Avatar
Daniel60
Dude are those Cmdp worth it?
Old Apr 25, 2008 | 09:36 AM
rshamekh's Avatar
rshamekh
Yeah I noticed some high end power increase, but it hurts the low end torque a bit. Gears should help fix the low end torque loss.
Install is easy as well.
Old Apr 25, 2008 | 10:56 AM
SuperSonic05's Avatar
SuperSonic05
I don't have a big pic of her.
if you us the steada bolt make sure you only turn it a few times.
Old Apr 25, 2008 | 04:20 PM
ThumperMX113
ORIGINAL: rshamekh
Sounds like you need to get a tune from Justin at VMP Tuning. I had him dyno tune my car after doing the CMCVs and I didn't lose ANY power ANY where. I did gain more power mid-top. But it was a gain all across the power curve. I didn't lose any gas mileage either. Actually gained .5 mpg. I gained 12 rwhp from both the UDPs and CMCVs.
Old Apr 25, 2008 | 04:34 PM
Larmo's Avatar
Larmo
very small increase on the butt dyno with UDP, but an increase nonetheless.
Old Apr 25, 2008 | 05:11 PM
Pwny's Avatar
Pwny
I noticed a higher pull later in the RPM range. I could definitely feel it.
